2006 PHOENIX cRUISER 2551, Lock on entry door broke
  • 14117 Views
serrano4657
  • 43
  • PurchDate: May, 2019
  • ModelYear: 2006 2551
  • ExtColor: Blue/White
« on: January 04, 2024, 07:39:28 pm »
Hello, my entry door lock on my 2006 2551 rv broke.
I can only keep the door close by the second lock.
I had read that these locks used cheap metal and are known to break.
Is there a replacement lock I can buy that will fit the same hole?
LRUCH
  • 238
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • ExtColor: White/Sage
Re: 2006 PHOENIX cRUISER 2551, Lock on entry door broke
« Reply #1 on: January 04, 2024, 08:42:27 pm »
I found this one on sale on Amazon and it was a tight fit.... Needed just a bit of filing on the welds inside the opening.
https://www.rvlock.com/collections/best-sellers/products/class-c
It fits the thicker doors on our PCs.... I tried 3 other electronic locks that couldn't handle our thick doors. I like that I can tap the remote and lock the door from the driver's seat, in case I don't remember if I locked that door. I have used the keypad for entry/exit when parked on a beach and eliminated keys in my swimsuit (with the fob in a zip lock bag since it is not waterproof) ,,, another bonus.
After 8 months, what I don't like is that it is black. My original was white. So, I'm thinking of taking it out, disassembling it, and having it powder coated white.   Otherwise, no issues.
Larry
« Last Edit: January 11, 2024, 06:13:55 pm by LRUCH »
Larry
Taildragger
« Reply #2 on: January 11, 2024, 01:17:25 pm »
Finding a replacement lock that fits in the thicker Phoenix Cruiser door is an issue.  The Atlas Keyless Lock System is designed to replace the troublesome TriMark lockset.  The Atlas  provides key access with the option of user --programmable combination code and a wireless key fob.   The weatherproof keypad is backlit for easy visibility even at night.  .
Woodchuck
  • 85
  • PurchDate: 04/2021
« Reply #3 on: January 12, 2024, 07:06:19 pm »
Try latchfix.com. Easy fix & fast shipping.
Chuck & Sheila
« Reply #4 on: January 13, 2024, 07:35:43 am »
Agree on latchfix.com.  Works great!
Taildragger
« Reply #5 on: January 17, 2024, 07:42:39 pm »
The Latchfix product gets good reviews. I ordered the repair kit when the OEM pot metal mechanism from TriMark broke.  When the precision machined components in the repair package wouldn't fit, I consulted with the Toolmaker at Latch Fix.   He told, an undocumented change to the original lock design was made to correct a flaw in early versions and was never referenced in any nomenclature.  Because of the change the repair kit doesn't' fit some early versions of the lock.  His explanation included the caveat that incompatibility persists because stale warehouse inventory and the distribution channel was never purged.
The problem is with TRIMARK.  The company modifies the product unilaterally without changing the nomenclature. Several versions of the latch exist. Part Numbers are obscure and the risk of getting the old pot metal "nonmagnetic" construction continues.  TRIMARK considers their mechanism as "military" grade and boast about their product line being installed on high dollar vehicles around the world.  When searching for a replacement, I considered them and contacted Sales Personnel there.  As if a salesperson's lack of product knowledge could be disguised as a need for a high degree of technical sophistication being required for a customer to order a doorlatch was an issue, I found their service loathsome.
