Door opener & lock to pc 2551 2009
  • 10265 Views
rulenh
  • 5
« on: August 17, 2023, 04:03:48 pm »
I have been in & out of my 2009 PC 2551 many times today, but the last I shut the door , now it will not open. I went inside over the front seat to see if I could get it open from inside.
No luck .All locks are off. Any help would be appreciated.
Thanks!
Re: Door opener & lock to pc 2551 2009
« Reply #1 on: August 17, 2023, 04:13:40 pm »
Common problem with RV lock. Pot metal breaks. You can push the plunger with a screwdriver from inside where it latches. When door open it will fly away with the spring. Search on this forum you will see where to buy a replacement plunger or an entire new lock assembly. Read them all.
Taildragger
« Reply #2 on: August 18, 2023, 02:47:28 am »
One thing it seems is that eventually everyone has the door striker bolt failure.
Ordering a replacement is made more difficult by the door thickness of the Phoenix Cruiser.  While waiting for a replacement that fits, I operated the door by removing the striker bolt and used the deadbolt.  Key entry from outside.  Knob operation from inside.
« Reply #3 on: August 18, 2023, 09:15:54 am »
Get a steel striker are..  You can get them from http://latchfix.com there is a good installation video on the site.. Watch it and see if you have the skills (not a lot required) to fix it permanently.
