We are selling our beautiful unit - Just don't use it enough
Dual slide in a 27 foot motorhome.
Can be used without deploying the slides.
4K generator with 208 hours
Most lighting has been replaced with LEDs.
Leatherette seating very clean, no blemishes.
This unit is ready to go. See photo with service records.
Has always been stored in an insulated building or it has a cover which I have never used.
Has a set of factory graphics should they ever be needed.
A/C with heat strip.
Slide toppers, all seals meticulously maintained as well as the mechanicals.
New automatic step motor recently replaced.
59K miles, always has had synthetic oil at 3K intervals.
Recent trans, and coolant service, new ball joints and tires rotated.
There is one spot on front wheel flare that the clear coat has lifted. Quite minor.
See service records, new Bilstein shocks and stabilizer, recent brakes, tires good!
$32,500 Located in the beautiful Black Hills of South Dakota.
Please call or text (719) 640-5917
*Forum Disclaimer: Photos are only visible to members that are registered on the forum. If you would like to see photos of this product, you can register on the forum or contact the seller and request they send photos to you.*
