Sewer Pipe
  • 9669 Views
Gracie
  • 5
  • PurchDate: MAY, 2011
  • IntColor: BROWN AND LIGHT MAPLE
  • ExtColor: BROWN/RUST
Sewer Pipe
« on: May 12, 2011, 12:59:38 pm »
Hello:  We are new to Phoenix Cruiser and need help transferring the wash water to the 3" sewer pipe instead of the sani-con.  Can someone tell us the steps please? Please list here or call 479-521-1809.  Thanks Gracie.
P.S.  We know where it is located but have not been able to send fluid through it.
« Last Edit: May 12, 2011, 01:08:38 pm by Gracie »
Re: Sewer Pipe
« Reply #1 on: May 12, 2011, 01:06:08 pm »
just before the sani-con, under your rig should be the attachment for the "Stinky slinky"  I have used a 90 Degree elbow there to a 10" extension which brings it out for easy access.
Re: Sewer Pipe
« Reply #2 on: May 12, 2011, 04:41:06 pm »
In order to get the water to come out the 3" sewer pipe you will still need to open the valves using the motorized boxes in the sani-con compartment. What really happens when you open a valve the water runs into the 3" pipe and the sani-con pumps it from this pipe. If you don't want to use the sani-con, hookup a hose to the end of the 3" pipe and open the valve, after placing the other end in the sewer hole.
« Last Edit: May 12, 2011, 04:43:08 pm by TomHanlon »
