Size & kind of sewer hose & gauges
  • 8556 Views
Bluet Stallings
« on: January 17, 2023, 02:52:16 pm »
Hello all, I have just bought a new TRX. It was delivered to me, so no walk through. First question, I have bought one sewer hose, that because of fittings on each end, will not fit in holder. It is about 3 and a half inches in diameter. Can any of you recommend a brand that will fit. Nothing in manuals to help me. Second question, the gauges on wall, what does the esc reading mean. It is blinking red w/different numbers. Again, nothing in manuals. Also, water has leaked, maybe from window, and is under sofa on floor. For those of you with experience, do I just need to caulk window? Thanks in advance for all your help. I feel stupid asking these questions because I have owned several motor homes, but Philly is not calling me back!
Re: Size & kind of sewer hose & gauges
« Reply #1 on: January 17, 2023, 11:13:23 pm »
I had the same issue with a Rhino Flex heavy duty sewer hose kit. Any standard 3” slinky with a bayonet fitting for the rv end should fit in the storage tube. You may have to insert the 90 degree elbow fitting into the other end  before each use. That comes with the matching threaded ring to connect to the campsite drain pipe. Camping World should have  everything online.
https://www.camco.net/hts-10-standard-sewer-hose-w-straight-hose-adapter-bagged-39604
https://www.camco.net/sewer-fittings/easy-slip-4-in-1-sewer-adapter-4-in-1-sewer-adapter-39144
If you have a user manual for the Xantrax inverter it should cover the display and control settings.
Call or email Dave Ponsler at Phoenix about the leak. If you need to re-caulk  a window under warranty you want to make sure to use the right stuff.
Happy Trails, and welcome to the  PC forum
« Reply #2 on: January 18, 2023, 07:17:29 am »
What dealer delivered to you?  Someone should have given you a walk through.
Bluet Stallings
« Reply #3 on: April 27, 2023, 12:25:00 am »
Thanks for the replies. Currently, I am putting my sewer hose in a trash bag, in one of the compartments. Next time I get near a camping world, I’ll check those out.
RV was delivered from Camper’s Inn in Philadelphia to Atlanta and driver knew nothing about it.
Besides my window leak, the step stays out, in spite of switch being off.
Because of my worsening health, I will have to sell after I get everything fixed. I love the TRX!
