Holding tanks not draining through macerator
  • 27 Replies
  • 37934 Views
Gixxerkid3
Re: Holding tanks not draining through macerator
« Reply #15 on: October 04, 2022, 07:10:26 pm »
Anxious to know what the issue was.
« Reply #16 on: October 04, 2022, 10:39:10 pm »
Me too.   I guess I have no life.   Lol
Gixxerkid3
« Reply #17 on: October 04, 2022, 11:00:30 pm »
Has to be something in the hose. Ironically, I just replaced my impeller about 2 weeks ago.  What a difference.  I have no idea how it worked previously since all the rubber blades were gone and literally disintegrated.  Anyway, on the edge of my seat with anticipation. 😂
« Reply #18 on: October 05, 2022, 04:22:46 pm »
I think if it were me having a problem like originally described I would probably do the following:
1.  My PC has a cover on the big hose dump port and on that cover is a regular garden hose connection with a cap.
2.  I would take one of my old (I have a couple of used ones I keep for various uses) washing machine hoses (they have female hose couplers on both ends) and attach to that dump port at the hose connection, leaving the cover in place.
3.  I would then hook up my garden hose to the free end of the washer hose.  I would also have my standard 40 pound rv hose regulator hooked up to the garden hose.
4.  I would make sure both the black and grey tank valves were closed and I would turn on the 40 psi fresh water hose, forcing a back pressure into the macerator pump which would already be turned on and see what came out, if anything.
5.  If nothing came out, I would know the problem was probably in the pump or right at the pump.
6.  If she no go, I would disassemble the pump.    I am reluctant to mess with my pump because I have had lots of problems with the way PC mounted it and I have pretty successfully remounted it to better align with the rigid pvc from the tanks.  Essentially, road vibrations would cause the bayonet to pop a leg and I would have to replace it as I recall.  I modified it soon after I got it ten years ago last month and it is storage now so I can't recall in detail just what all I did to elevate the problem.
« Reply #19 on: October 05, 2022, 08:00:15 pm »
Holly crap … that’s a lot of work.   You must charge by the hour.  LOL
« Reply #20 on: October 05, 2022, 10:35:32 pm »
I suspect the whole process would take less than ten minutes.  Hooking up a short hose, hooking up a garden hose to it and turning on the macerator to see what happens?   Seems simple to me.
« Reply #21 on: October 06, 2022, 06:23:25 am »
Slight topic detour - our bayonets cracked not long after purchase. The repair shop we took it to was aware of a problem with faulty parts, contacted the manufacturer and it was repaired free of charge. No problems since. It was not associated with the way it was installed.
  • 5744
« Reply #22 on: October 06, 2022, 08:31:36 am »
Was that a manufacturing issue around 2013 when your PC was new?.....Just trying to put a timeline on the window of poor manufacturing of 3" sewer components with bayonettes.
The bayonette breakage was most likely caused through the use of an inferior formula of plastic which could have affected every 3" sewer component with and without bayonettes.  It simply shows up first in the highly stressed bayonettes.  Maybe as age and vibration continues, other failures within the sewer system may occur.
I assume the parts were imported from China.......enough said about that.
« Reply #23 on: October 06, 2022, 10:21:53 am »
I’m guessing we’re talking about Thetford part #70405.   That part has always been a weak design. I’ve never been able to find an alternative. If you wait till summer it’ll cost you $55-105 if you can find one.  Buy it in the off season and it’s usually in the mid $30s.  I bought an extra after one of the tabs broke on a horrific road in Texas.
« Reply #24 on: October 06, 2022, 10:53:20 am »
Done working.   Took me that long just to read the process
« Reply #25 on: October 07, 2022, 05:52:17 am »
Our PC was picked up May 1, 2013. I don't know the time frame for faulty parts. We were just lucky the shop we took it to knew about it and bounced it back to the manufacturer.
George Nauman
  • 42
  • PurchDate: 10/2014
  • ExtColor: Cafe
« Reply #26 on: October 13, 2022, 10:34:11 am »
Hi all - sorry for the radio silence, busy driving home. Good ideas to try, once I can find a little help. Back problem makes it difficult to get down there to work on it. I’ll try to con one of the kids into helping (maybe if I don’t tell them what it is…  ;) ). It’s being winterized and stored today, but maybe I can get it some nice day yet this fall and play around with it. Thanks again for all the ideas.
« Reply #27 on: October 13, 2022, 03:47:39 pm »
I wish I was closer, I’d do it for you.
