What model velvac mirror
  • 10065 Views
Tarnold
  • 247
  • PurchDate: Dec 2019
« on: August 20, 2022, 11:58:04 am »
(How long should a post take to show up?) looked at all the velvac schematic I could find, but couldn’t find mine. What model do you find on the 2013 e450.  I want to remove and repaint just the mirror shell, not the arm.  Removed set screws but still wouldn’t lift out. Ideas?
Terry
« Last Edit: August 20, 2022, 07:17:08 pm by Tarnold »
Tarnold
  • 247
Re: What model velvet mirror
« Reply #1 on: August 20, 2022, 12:02:35 pm »
Well, that one popped right up.  As above, removed the 2 set screws, but there seems to be a “split washer” type thingey with 2 slots 180* apart.  Thinking a flat blade driven at the right angle would loosen this ring and allow mirror to lift off of arm.  What says you?
Terry
LRUCH
  • 238
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • ExtColor: White/Sage
« Reply #2 on: August 20, 2022, 12:19:54 pm »
Sorry..  I have no personal experience with VELVAC,  but the vendor has a page dedicated to repair and replacement.  It may prove useful.
https://www.velvac.com/resources/field_resource_type/technical-document-57
Larry
Larry
Tarnold
  • 247
« Reply #3 on: August 20, 2022, 12:32:13 pm »
Looked at all of those, but nothing like mine?  Maybe I’m just assuming velvac?  The bottom of the mirror housing has a (looks like a ball) that rotates within a cup.  The 2 set screws holds it from rotating.
