Improving Air Quality In Your PC
  • 8686 Views
Engineerlt
« on: June 06, 2022, 08:00:53 pm »
Hello All
I was wondering  if anyone has done anything besides clean there A/C filters to improve their coaches air quality? I am going to invest in a I-Wave-M by Nu-Calgon. It is an air ionization system and helps with everything from killing virus's, mold, covid-19 etc. My reasons are that these PC are pretty air tight and when we are just using the hvac units we are not getting any air exchange from out side and just recirculating the air inside. Its good against allergens as well, this is where it would greatly benefit my wife. If any of these things are of a concern to you, check-out this I-Wave-M. I am going to wire it to the evaporator fan circuit. Oh I am currently putting one in my HVAC unit at home, its the I-Wave-R.
This is from the website
iWave-M is a flexible ion-generating bar that can treat IAQ in nearly any HVAC application. The air purifier provides the highest level of ionization energy in the most compact size available in the market, producing 240 million ions/cc per foot of flexible ribbon. The highly versatile iWave-M is low maintenance with no replacement parts. As the air flows past the iWave-M, the device emits positive and negative ions, creating a plasma region that purifies the air, killing mold, bacteria and viruses in the coil and living space. The ionization process also reduces allergens, smoke and static electricity, as well as controlling odors (cooking, pet, VOCs) and other particles (no more sunbeams) in the air without creating ozone or any harmful byproducts.
iWave-M’s revolutionary circuit bar with special integrated ion-generating needles fits any HVAC cooling coil up to 36" wide and up to 1200CFM. The circuit bar is chemical resistant and highly durable for long service life. Plus, it can be folded to length in the field to any size and uses hook and loop fastener material for the flexible bar and power pack for easy installation. It is perfect for ductless HVAC systems – specifically mini-splits, commercial VRF coils, PTAC systems – plus residential and commercial duct systems, packaged systems, transport cooling coils or even in ice machines. The iWave-M is the most versatile and novel product on the market to address air quality for any HVAC system, in particular to solve mold issues common in hard-to-clean ductless systems.
Specifications:
Input Voltage: 110VAC to 240VAC
Power (VA): 5 Watts
Frequency: 50/60 HZ
Output Voltage: 5 KV
Power Supply Dimensions: 2.0" W x 1.0" H x 3.0" L
Flexible Bar Dimensions: 1.25" W x 0.05" H x 36" L
Power Supply Weight: 0.5 lb.
Electrical Approvals: UL and cUL approved
Service Temp. Range: -40ºF to 160ºF
Very Respectfully
Lance
Re: Improving Air Quality In Your PC
« Reply #1 on: June 07, 2022, 01:52:27 pm »
Might be the greatest thing ever but I disagree on pc being airtight. We clean the inside spotless and lock her up. A couple of dust ups and when we open her up she needs a good dusting. I expect that’s with any RV
jim.godfrey
  • 292
  • PurchDate: October 2019
« Reply #2 on: June 07, 2022, 07:22:33 pm »
Looking forward to a full report Lance!   2o2
