Water Valve Settings
  • 8 Replies
  • 8326 Views
custerhank
  • 138
  • PurchDate: March/2020
  • IntColor: Brown
« on: May 06, 2022, 01:08:18 pm »
  Does anyone have pix of the water valve handle settings under the kitchen drawers? We have a 2019 3100, are on our first summer adventure and having a senior moment. Dewinterizing went fine but hot and cold are sporadic and are changing at will each spigot. Who would imagine there are so many possible combinations of valve settings? I just assumed all the handles should be "on" (parallel to the water lines) for summer use but does not seem so. Pix via email (hanknjoyce@netzero.net) or text (443-799-0045) would be most appreciated. Or just post here.
  Thanks,
Hank
Custer, SD
Currently in Fort Wayne, IN visiting family for 10 more days
Hank & Joyce Whitney
Custer, SD
2019 PC Model 3100
  • 437
Re: Water Valve Settings
« Reply #1 on: May 06, 2022, 03:07:48 pm »
Hank, the center valve should NOT be "On"--parallel with the pipe--it should be "Off"--cross-wise.  The two outside valves should be "On"--parallel with their pipes--just as you have them.
With the center valve also in "On" position, it is allowing hot and cold water to mix at that point.
Mike
custerhank
  • 138
  • IntColor: Brown
« Reply #2 on: May 06, 2022, 03:11:00 pm »
Tks for prompt reply. MY DW will be most happy when she returns from an outing with granddaughter!
Hank
Custer, SD
2019 PC Model 3100
  • 5671
« Reply #3 on: May 06, 2022, 06:07:03 pm »
For Clarity.
« Reply #4 on: May 06, 2022, 08:31:07 pm »
Good diagrams Ron!
Engineerlt
« Reply #5 on: May 07, 2022, 07:40:39 am »
Hey Ron
Those are cool diagrams, you've got a lot of tricks up your sleeve!
Very Respectfully
Lance
  • 5671
« Reply #6 on: May 07, 2022, 09:56:01 am »
Thank you.
I just googled and found it.  If you want to share the diagram with other RV owners, here is the link for sharing or downloading.
https://i.pinimg.com/564x/41/ad/1d/41ad1d1757e6c3c13f07273362d29623.jpg
RonJ
  • 126
  • Ron & Pilar
  • PurchDate: 10/2020
  • ModelYear: 2020
  • ExtColor: Greystone/Custom
« Reply #7 on: May 08, 2022, 05:21:19 pm »
Very helpful Ron.  Thanks
RonJ
RonJ
custerhank
  • 138
  • IntColor: Brown
« Reply #8 on: May 21, 2022, 08:50:48 pm »
  A belated Thank You for that great diagram. Very helpful. Even I can understand it. Do you think the next edition of the PC Owner's Guide will include it? Sure would help along with other diagrams/pix about where to find stuff like drain/shut off handles etc. I know the factory cannot cover all the bases (You Tube videos do help) but I was surprised by the lack of specificity in the latest Owner's Manual and the abundance of generalized instructions. But, to be fair, they do answer my questions when I call.
Hank
On the road at Fort George G. Meade, Maryland
Custer, SD
2019 PC Model 3100
