Oh crap, leaks!
  • 11052 Views
RollinInn
  • 13
  • PurchDate: 2/2022
  • IntColor: Desert Sand/Cherry
Oh crap, leaks!
« on: April 11, 2022, 09:54:11 pm »
Since bringing home my PC, the 1st really hard rainstorm hit last night into this morning &, of course, now I find leaks.   First I heard a drip coming from near the driver's side step well.  I look up & found the headliner above that side of the dash pretty dang wet. Wet enough to drip into the step well.   I checked the inside of both the small cabinets to either side of the TV & I could feel those headliners were damp & there were some drips of water on the bottom of the cabinets.
The problem is 2 fold:
1. It's parked in my driveway with a nose low, 1 bubble completely outside the circle, off level.  The only way to make it actually level, even with boards under the jacks, is to take the front wheels off the ground by a good bit...which I don't want to do.  I know I CAN have them off the ground (the parking brake is on & I've got heavy chocks in front of the rear tires, but I don't want to.  It's also less than half a bubble low on the driver's side, which is the reason the water is dripping in on that side. It's being channeled there by that lean.
2. I got on the roof during a lull in the rain & found cracks in the seals between the cap & the roof, especially where it makes the curves to meet the sides.  Just to see, I checked the rear cap & found similar separation in places.   This is completely on me.   It was 17 degrees the day I originally looked at it & it was 32 degrees with 15-20mph winds the day I picked it up so I didn't get on the roof to make a proper inspection.  I take full responsibility. Otherwise, I would've caught this.  I did check inside all cabinets both when I first saw it & again when I picked it up, but those front cabinet headliners didn't have stains nor was there any water spots on the cabinet bottoms.   If water did get in before, it was dried & not noticeable when I looked inside all the cabinets both times.
It's going to rain, & somewhat heavily, for the next 2+ days.  Unfortunately, because of the nose down position, that rain is going to keep getting into the roof cracks & into my coach. :'(
Any suggestions of what I can do until I can get it back to the dealer to fix?   I'm actually a bit sick to my stomach about this because I know what damage water infiltration can do & I don't know how long this has been going on.   The dealer got it in December, put it on their website in January, I bought it in February but just picked it up about 10 days ago.   There's been all kinds of rain/snow/ice on it in that timeframe.
« Last Edit: April 11, 2022, 09:58:38 pm by RollinInn »
Lori 🍷
2016 Phoenix Cruiser 2350S towing 2014 Honda CRV EX-L
"RV there yet?"
RollinInn
  • 13
  • PurchDate: 2/2022
Re: Oh crap, leaks!
« Reply #1 on: April 11, 2022, 11:01:41 pm »
Update....I emailed the dealer just before I posted above, not even dreaming I'd hear from someone after hours.   It's 11PM & the dealer replied, they're sending someone tomorrow to pick it up.  I'm 3hrs away from them.  Now THAT's service!
Lori 🍷
"RV there yet?"
Engineerlt
Re: Oh crap, leaks!
« Reply #2 on: April 12, 2022, 06:48:49 am »
There is an issue that I should never have to deal with, roof leaks. The Flex Armor roof coating has been excellent. RV FlexArmor is the only pure polyurea, sprayed RV roof in the RV industry. It was created to address the weak points in RV roofs such as caulking and tearing. It provides a totally seamless roof that requires no more yearly maintenance or special cleaners. RV FlexArmor was the first RV roof alternative to offer a written lifetime no leak guarantee and is still the best solution on the market for fixing your RV roof.
Very Respectfully
Lance
Re: Oh crap, leaks!
« Reply #3 on: April 12, 2022, 08:50:12 am »
So apparently the severe lean funneled all the water toward those two breached corner seams.  In the mean time, could you park the rig tail-high to direct the water away from them?
A repair seems to be quite an easy DIY project.  Be sure to dry everything out extremely well.
« Last Edit: April 12, 2022, 08:52:02 am by Ron Dittmer »
RollinInn
  • 13
  • PurchDate: 2/2022
Re: Oh crap, leaks!
« Reply #4 on: April 12, 2022, 03:25:28 pm »
Thank you both.  i will look into the RV FlexArmor.  Eventually there's gonna come a day when I can't get up there to do yearly inspections & not having to worry about leaks would be worth the install cost.
The dealer rep picked it up today.  The PC came with a 30 day warranty & really, this should've been caught when they got it & they went through their checklist.  I'm hoping the warranty will cover some of the repair.
Lori 🍷
"RV there yet?"
