2350 Entry Door Hinge Pins
  • 14624 Views
CABass
  • 42
  • PurchDate: 10/2018
  • ModelYear: 2004
  • IntColor: Tan
« on: March 19, 2022, 07:24:16 pm »
The entry door on my 2350 has started to sag a little and drags on the bottom of the doorframe when I open and close it. I can wiggle the door vertically by grasping it at the bottom, there is just a wee tiny little bit of slop in the door hinge pins.
If you have replaced your hinge pins, what did you use?
2004 2530 Ford
Tarnold
  • 247
  • PurchDate: Dec 2019
Re: 2350 Entry Door Hinge Pins
« Reply #2 on: March 20, 2022, 09:22:57 am »
Mine does the same.  I lifting the door and inserted a “C” clip under the hinge pin.   It helped for a while but it finally slipped out.  It is a quick and easy if you can get it to stay in.
CABass
  • 42
  • ModelYear: 2004
  • IntColor: Tan
« Reply #3 on: March 20, 2022, 03:34:48 pm »
Good suggestion.  Thank you.
2004 2530 Ford
CABass
  • 42
  • ModelYear: 2004
  • IntColor: Tan
« Reply #4 on: March 20, 2022, 03:41:35 pm »
2004 2530 Ford
