Electric ice chest
  • 17 Replies
  • 26205 Views
Bangorbob
  • PurchDate: 6/10/20
  • IntColor: Slate Grey
  • ExtColor: Slate Grey
Re: Electric ice chest
« Reply #15 on: September 04, 2021, 11:58:30 am »
Bob, interesting, thank you for the info.  Please post how it works out once you’ve used it for a while.  I’m assuming you’ll fill it with pre chilled drinks. I’ll be curious how well it keeps things cold.
I have already used it quite a few times.  I live about 1 1/2 hours from Nellis AFB.  Once in a while we go to the commissary and we use the cooler.  Works fine.
« Reply #16 on: September 05, 2021, 01:09:06 am »
If you buy the Igloo or an equivalent, be aware that even a small Thermoelectric cooler aka Peltier cooler consumes a lot of amps, so only use it while driving with the alternator charging the batteries or when plugged in to shore power.  TEC’s are cheap but also very inefficient.
« Reply #17 on: September 05, 2021, 06:44:23 am »
If plugged into a 12v dashboard outlet, remember, the vehicle battery is not charged when plugged into shore power unless you have a TrickLStart or something similar.
