Lithium Battery Installation
  • 32 Replies
  • 27856 Views
wideglide
  • 96
  • PurchDate: 6/2026
  • ExtColor: gray
Re: Lithium Battery Installation
« Reply #30 on: November 25, 2026, 08:47:37 am »
Thx calcruiser and Lruch.
Im still waiting delivery on the batteries so im researching everything. I plan on making new jumpers for cross connecting the batteries so they are exact length and resistance. I want to make sure they stay as balanced as possible and dont discharge at different rates. Given the short lengths of cable it really shouldnt make much difference but i like things to be as right as possible. Im nerdy like that. I havent really had much issues with the old batteries losing too much charge since i replaced the converter. In the beginning i was having to keep a battery charger hooked up just about all the time to keep up the 12v so the ac would run while i was fixing all the problems i had when i got the PC. Thats why i wanted to replace the batteries as they didnt seem to hold much charge for very long with minimal load. Will be nice to have 200aH of lithium power at my disposal.
So i found this nugget in my research that looks like a much cheaper alternative to a dc-dc charger for the alternator side of the equation  that will regulate the charging from the alternator, integrates the emergency start circuit, and provides charge sharing when hooked up to shore power to assist in charging the coach battery as needed. Im still in research phase but i see no other mention of this in the forums. Lots of youtube info out there as well.
So now after more research i think ill go with the Orion XS dc-dc charger to handle the alternator side. Im more of a safety minded over cheap kinda guy but wanted to leave the info up for reference. The li-bim provides no current limiting and relies on the timer circuit to keep from overheating the alternator.
« Last Edit: November 25, 2026, 12:43:30 pm by wideglide »
  • 695
« Reply #31 on: November 25, 2026, 12:58:19 pm »
The BIM device does not appear to be a step up (buck- boost) transformer. If it’s just a switched relay you may not see  14.4v from your alternator under any conditions. Check it with a voltmeter   before pulling trigger.
Ford used several different alternators ranging from 90A to 130A. The number of holes in the front of the housing is the simplest way  identify what you’ve got. VIN lookup is useless.
« Last Edit: November 25, 2026, 01:17:36 pm by CalCruiser »
wideglide
  • 96
  • PurchDate: 6/2026
  • ExtColor: gray
« Reply #32 on: November 25, 2026, 01:16:09 pm »
Yessir,
I decided to go with the victron orion dc-dc set up as  you and others mentioned above. ANd i DM'd you about that diagram.
