Adding A Propane Tank Shield On Our 2007 2350
  • 42029 Views
« on: May 18, 2021, 07:23:52 pm »
This has bothered me for 14 years.  I finally got around to making a shield for our propane tank that was always fully exposed to the rear tires as shown here.
I bought a truck mud flap from a truck stop during one of our vacations.
I measured and cut out my shield, first with my table saw, followed with a large scissors for the detail work.
I used a generic perforated bracket for mounting it.
I used hardware I had around the house including nylon locking lug nuts.
Cost was only that of the mud flap which as I recall was around $25.
I assembled it followed by a final fitting, then decided to adjust the lower-right area for improved clearance to the leaf springs and parking brake cable.
Here it is installed and the project finished.
I screwed the perforated bracket up into and through the PC wheel well liner into the steel above it.  It wasn't too thick, the large screw was able to self-tap into it.  I got lucky, in that there was a large production hole in the thick hardened steel main cross frame to allow the screw to the far right to pass through it into the steel above.
« Last Edit: May 18, 2021, 09:51:49 pm by Ron Dittmer »
Tarnold
  • 247
  • PurchDate: Dec 2019
Re: Adding A Propane Tank Shield On Our 2007 2350
« Reply #1 on: May 22, 2021, 09:27:02 am »
Did something similar.  If you have a tractor supply company nearby, they sell horse stall mat by the foot.  Works like your truck mud flap.
« Reply #2 on: May 22, 2021, 11:53:27 am »
Ah!  Good tip.
Cropduster
  • 124
  • PurchDate: 05/2015
  • ModelYear: 2002
  • IntColor: Brown
  • ExtColor: Brown
« Reply #3 on: May 25, 2021, 05:32:54 pm »
Herr Dittmer,  Das ist hervorragend!
Thanks for the information and pictures.
- CD
