Folding sanicon hose
  • 21 Replies
  • 21771 Views
RonJ
  • 126
  • Ron & Pilar
  • PurchDate: 10/2020
  • ExtColor: Greystone/Custom
Re: Folding sanicon hose
« Reply #15 on: May 13, 2021, 10:31:12 am »
Here's mine
RonJ
jim.godfrey
  • 292
  • PurchDate: October 2019
« Reply #16 on: May 13, 2021, 09:25:48 pm »
RonJ: I'm going to print this pic out and paste it in my sewer compartment! (JK)  roflol
I just ran out to the camper to try it and found that my hose is  about 4' longer, but with one extra partial loop I was able to get it in there though not as neatly as yours.
The thing I was missing was to use the top left clip for the outlet fitting. I was always trying to close the door with that floating and it has always been a struggle.
Thanks for the pic!  2o2
RonJ
  • 126
  • Ron & Pilar
« Reply #17 on: May 13, 2021, 09:41:07 pm »
Glad to help, Jim. Is your hose 4 feet longer or 4 inches longer? If mine was any longer I can imagine how much more difficult it would be to cram it all in.
RonJ
jim.godfrey
  • 292
« Reply #18 on: May 13, 2021, 09:54:12 pm »
I think it might be almost 4 feet longer. Though I just got back from a  campground where I had my hose stretched out to the max for a few days so may not have returned to original length yet.
Will take a closer look tomorrow and maybe measure it.
« Reply #19 on: May 14, 2021, 07:54:24 am »
It is possible the hose is the same length but has liquid in it.  You want to make sure your hose is empty when storing it.  When I am done dumping, I shake the hose starting at the PC, working my way to the outlet.
FWIW:  Mine stores exactly like RonJ's though his is perfectly stacked.
jim.godfrey
  • 292
« Reply #20 on: May 17, 2021, 07:47:15 pm »
Finally got around to checking the hose length.
Hose is empty, and in a relaxed state it is about 13.5' long.
With moderate pull it can be stretched to 17'
I tried again to stack my hose like Ron's but found I needed to make an extra loop indicating I have some extra length.
Maybe 3-4 feet worth.
My storage compartment is about 42" long meaning I would need almost 4 lengths (162" / 42" = 3.86) where Ron got his to fit in 3 lengths of the compartment.
But now that I see how to secure the end fitting properly it is much easier to get it all closed up without undue pressure on the latches.
Thanks again!
« Reply #21 on: May 17, 2021, 07:51:43 pm »
Jim,
You seem to have a longer sanicon hose than I do.  My 2007 2350 stores exactly like RonJ has pictured.
My hose will soon be shorted a little because I developed a pin-hole leak close to the pump.  I dabbed some silicone caulk which has been holding well for a few years so far, but when it gives out, I will shorten it by that much.
« Last Edit: May 17, 2021, 07:56:29 pm by Ron Dittmer »
