Original A/C Unit
  • 11 Replies
  • 15457 Views
Bangorbob
  • 260
  • PurchDate: 6/10/20
  • IntColor: Slate Grey
  • ExtColor: Slate Grey
Original A/C Unit
« on: February 25, 2021, 02:46:57 pm »
I thought I had the paperwork for the accessories/etc for our coach.  Guess what I am missing-yes the a/c brochure.  I believe my 2008 2350 came with a Dometic Penquin.  Does anyone know for sure?
Tx, Bob
  • 5719
Re: Original A/C Unit
« Reply #1 on: February 25, 2021, 03:17:01 pm »
My 2007 has a Dometic Penguin.  Since we have the full body paint, the a/c cover was painted to match.  The paint shop painted right over the a/c decals.  If your a/c unit cover is painted, just maybe if you examine it closely, you can read it like I can.
Bangorbob
  • 260
« Reply #2 on: February 25, 2021, 04:52:28 pm »
Ron,  I know you and I have basically the same.  You are correct as them painting over.  I am going to install the Easystart, therefore I needed the correct wiring diagram.
Thanks, Bob
« Reply #3 on: February 25, 2021, 07:36:51 pm »
If it looks like this, it's a Dometic Penguin (I or II doesn't matter)
  • 5719
« Reply #4 on: February 25, 2021, 10:01:07 pm »
That must be the "New Look".
Here is my painted 2007 model.
Oh, I found this picture of our unit inside.  It says it all.
The screws that hold the cover on are special with a shoulder.  Don't loose any.  Washing my rig a few years ago, I noticed one of the 4 screws was missing.  I bought a few through Camping World.
« Last Edit: February 25, 2021, 10:13:57 pm by Ron Dittmer »
  • 5719
« Reply #5 on: February 25, 2021, 10:10:08 pm »
Thanks, Bob
Just remember what I suggested about the Softstart/Easystart unit in that other post.  Mount it vertical or second best at an angle to prevent water from traveling down a wire and into the unit.  That video of the guy mounting it sideways with the wires not looped downward seems like he will later have trouble.
Bangorbob
  • 260
« Reply #6 on: February 27, 2021, 11:43:51 am »
Thanks for the tip on placement of the Soft start.
The question of the day.  IF you have replaced your penquin A/C shroud-What shroud did you replace it with?
Please don't tell me to call the factory-already did.
  • 5719
« Reply #7 on: February 27, 2021, 01:38:08 pm »
My a/c cover is the original.
My brother's a/c cover got damaged in a hail storm.  It was an expensive item to replace.  The shop doing some general work on his rig took care of it for him.  I understand they ordered it directly from the a/c manufacture.
  • 686
« Reply #8 on: February 27, 2021, 01:43:08 pm »
Camping World sells oem Dometic replacement shrouds. Get the Penguin low profile part. I bought one in 2016 for under $100.
« Last Edit: February 27, 2021, 01:45:33 pm by CalCruiser »
gandalf42
  • 221
  • PurchDate: May.2017
  • IntColor: Hickory/Graystone
« Reply #9 on: February 27, 2021, 03:28:47 pm »
I don't recall the brand of air con I had on my previous RV but I was able to buy a replacement cover off of Amazon.
Mike & Pat Astley,
Tarnold
  • 247
  • PurchDate: Dec 2019
« Reply #10 on: February 28, 2021, 08:23:01 am »
Local Ford stealership bought me a new one when their trainee drove my Chinook into the bay and the door wasn’t all the way up.  Got it on Amazon.
Bangorbob
  • 260
« Reply #11 on: February 28, 2021, 10:27:36 am »
Thanks for the replies/info.  I will be ordering an ICON Penguin Dometic Duo Therm Air Conditioner Shroud, Polar White from amazon probable today.  Going to leave it white vs painting it-I think.
