Leak in sewer pipe
  • 20 Replies
  • 22996 Views
Re: Leak in sewer pipe
« Reply #15 on: November 20, 2020, 10:14:31 pm »
I will put some plumbers tape (as Ron shows above that is what we called it) to support the whole of it.
I thought plumber's tape was Teflon tape used on pipe threads to seal pipe joints.
« Reply #16 on: November 20, 2020, 11:15:24 pm »
Nope, it's a 1/2" wide strip of steel with holes in it about every inch.   Used to support long horizontal runs of pipe, like dryer vent pipe or sewer lines, etc.
« Reply #17 on: November 21, 2020, 09:13:03 am »
Here we call teflon tape ' Plumbers Tape' also. We call the perforated metal (and sometimes solid plastic) support strap ' Plumbers strap'.  Might be regional thing.
Bangorbob
  • PurchDate: 6/10/20
  • IntColor: Slate Grey
  • ExtColor: Slate Grey
« Reply #18 on: November 21, 2020, 09:55:55 am »
Mine had the same leak.   Got a 3 inch x 3 inch coupling like this:       https://www.homedepot.com/p/Fernco-3-in-x-3-in-PVC-DWV-Mechanical-Flexible-Coupling-P1056-33/100372296
I wrapped part of an old bicycle innertube around the pump and tightened the clamps.  So far it is holding.
gandalf42
  • 221
  • PurchDate: May.2017
  • IntColor: Hickory/Graystone
« Reply #19 on: November 21, 2020, 01:04:40 pm »
Glad to hear others call it plumber's tape. I went to Home Depot and ask a person for it last week and he showed me some kind of wide plastic tape. When I described what I was looking for he told me that was called strap and directed me to it. It's been so long since I had bought some, I thought I was getting senile and had forgotten the name. Good to know I am just old and the melon still works!  :)
Mike & Pat Astley,
« Reply #20 on: November 22, 2020, 12:22:05 am »
2o2
Here too....most of the time.  Just like a computer that is near full, I'm bogged down.  If only I could purge the 40 years of worthless work-related information to make room on my internal hard drive.  roflol
« Last Edit: November 22, 2020, 12:26:53 am by Ron Dittmer »
