Old Stereo System
  • 21 Replies
  • 24246 Views
Bangorbob
  • PurchDate: 6/10/20
  • IntColor: Slate Grey
  • ExtColor: Slate Grey
Re: Old Stereo System
« Reply #15 on: August 16, 2020, 10:03:33 am »
Ron, Thanks.  So this extension cord is from the factory.  Never seen that before.  BTW, how did you mount your power strip?
« Reply #16 on: August 17, 2020, 08:36:42 am »
Yes Bob, that cord is a "factory" thing.  Like you, I thought it was odd.  But it works.
I drilled holes in the power strip and screwed it to the shelf I made.  If you look close at the picture, you can see the nylon locking nuts at the bottom.
I got that power strip from my employer a long time ago, tossed out because the cord was damaged.  I rotated the receptacles into various orientations to accommodate various chargers.  Power strip receptacles are typically oriented in such a way that a charger often covers up an adjacent receptacle, and the wire coming off also interferes.  We like the charger and cord to hang down, out of the way of other chargers.  It works quite well.
I recall some time later, I stumbled on a power strip with receptacles that rotate.  I suggest some internet shopping.
« Last Edit: August 17, 2020, 08:43:37 am by Ron Dittmer »
Bangorbob
« Reply #17 on: August 17, 2020, 09:34:59 am »
Ron,   Thanks for the info.  I saw the 2 silver "things" on the bottom of the strip but didn't know what they were.  I'll have to look at my power strips to see what the internals look like.  You are a wealth of knowledge.  Thanks.
« Reply #18 on: August 17, 2020, 11:09:18 am »
Yes, you surely have to watch for internal wiring when drilling holes for the long machine screws to pass through the power strip.
When mounting the power strip to your own shelf or other feature, be sure to use nylon lock nuts because you won't be able to tighten it up enough without distorting the power strip.  It would start to collapse, then come loose anyway.  A proper size bushing through the core of the power strip would also work, but it is much easier to use a nylon lock nut.
You are very welcome!
« Reply #19 on: August 17, 2020, 06:11:41 pm »
That power strip with rotating sockets is a fantastic idea,
« Reply #20 on: August 17, 2020, 09:01:22 pm »
Doing a very quick search, I found a rotating power strip at Bed Bath and Beyond.  It includes two USB charging ports.  CLICK HERE to see it.
« Last Edit: August 17, 2020, 09:03:12 pm by Ron Dittmer »
« Reply #21 on: August 18, 2020, 10:08:12 am »
Same item on Amazon for $24.99...yes, I bought one.
