Horst Miracle Probes
  • 7 Replies
  • 20176 Views
Engineerlt
« on: February 03, 2020, 07:46:10 pm »
I am giving up on getting these button tank probes to operate properly.  I just received Horst Miracle Probes for my black and gray tanks. I found a great video online on how to remove the button probes, and already pulled them out.  It uses a box end of a wrench and washer to remove the button probes and they pop right out. So if any of you are wanting to change your probes or just pull them out its a lot easier then pulling or prying on them to try getting them out. So tomorrow will be the day I install the new probes and hopefully the tanks will read correctly for the first time since I have had the PC.
dogyard
Re: Horst Miracle Probes
« Reply #1 on: February 03, 2020, 08:12:34 pm »
Good info, I'm anxious to hear the results of your upgrade.  Can you post the link to the YouTube video that shows the removal process?  Thx.
WillLloyd
  • 216
  • PurchDate: Feb/2017
  • IntColor: Pebble
  • ExtColor: Grey
« Reply #2 on: February 04, 2020, 07:03:18 am »
I gave up on the OEM system last year after trying all the tricks, solutions, internet ideas, to no avail.  Installed this:  https://www.rvupgradestore.com/Garnett-Technologies-Model-709-SeeLeveL-II-p/709-1003.htm
Works great, gives readout in approximately 3-5% intervals, not the quarter tank steps.
Easy to install, uses existing wiring.  You do need the back plate since the existing hole is slightly larger than the new panel.
Engineerlt
« Reply #3 on: February 04, 2020, 08:47:07 am »
Here is the YouTube link for how to easily remove the tank probes.  It worked for me, made it super easy.
https://www.youtube.com/watch?v=lCHJ1ZF9Usk
Engineerlt
« Reply #4 on: February 04, 2020, 11:48:52 am »
Installed tested and checked for leaks, this is the first time the gray and black water tank level indication worked. Time will tell for how long but currently I couldn't be happier.
That Garrnett SeeLevel II monitoring system is very cool! That is a great find, looks like it would be trouble free regardless of inside condition of the tank. If this doesn't work I am going to upgrade to that. Thanks for the heads-up, much better system just a little pricey, but you get what you pay for!
« Reply #5 on: February 04, 2020, 02:26:41 pm »
The Horst Probes certainly look like an improvement over the buttons--and I hope they solve Lance's issues.  I want to take a minute to add my endorsement to WillLloyd's suggestion of the SeeLevel unit.
Phoenix has been installing the SeeLevel II system as an option for some period of time.  I got it installed in my 2552 that they built in late 2018.  I have mentioned before in postings how much I like the system, and so far I've had no problems with it.  WillLloyd mentioned readout in 3-5% intervals.  It actually provides readings more incremental than that.  On fresh, gray, and black water tanks I've watched them move in 1% steps as I've filled or emptied them; I haven't actually seen the propane increment move, but I suspect that duplicates the 1% movements.  Experienced RV'rs probably were more comfortable with dealing with such things, but being brand new to RV usage, I was a little apprehensive about monitoring how much water or propane I had left, or remaining tank capacity for black/gray water.  The SeeLevel system solved that for me, and as I gain experience I've really been comfortable knowing exactly where my levels are.  Don't know about the longevity yet----but it can't be worse than the track record for the standard systems, and from everything I could find reliability of the SeeLevel II is excellent.
« Last Edit: February 04, 2020, 02:32:59 pm by mikeh »
Engineerlt
« Reply #6 on: March 06, 2021, 09:02:37 am »
Well the Horst Probes have worked flawlessly for over a year now. It's been one of the best upgrades I made. If your tank level indicating system isn't working well checkout the Horst Probes.
I can tell you that my tank level system now operates when before I couldn't get my grey or black tanks correct level.
Easy install and won't break the bank...
« Reply #7 on: March 06, 2021, 01:15:12 pm »
Our PC will be 14 years old in a few months.  Our original tank sensors continue to work flawlessly.  I think it is because at the end of our RVing season, I bleach the gray and black tanks followed by a rinse, to remove foul odors.  Odors are a concern because our PC is stored in our garage, located under our bedroom.
I can't say my annual maintenance process will work for everyone, but it's worth a try if your tank sensors are not working properly.
I put 1/3 of a gallon of house-hold bleach in each tank, then fill the gray tank until I see it backing up into the shower, and the black tank until near the toilet valve.  I also add a little bleach in the closed toilet, sinks, and shower pan filled with water and bleach everything clean.  I need to be careful walking around to minimize sloshing.  I then wait 2 hours, drain everything on the driveway (yes the water smells fresh and clean), and repeat with fresh water, let sit another 2 hours, and drain again.
When I am done, our PC smells like brand new, our garage has no sewer gas odor, and the now 14 year old tank sensors work great.
« Last Edit: March 06, 2021, 01:17:02 pm by Ron Dittmer »
