operating the back up cameras
  • 1 Replies
  • 8164 Views
LynnWM1894
  • 4
  • PurchDate: September, 2019
  • IntColor: Beige
  • ExtColor: Gold/Brown
« on: January 27, 2020, 07:40:54 pm »
I have a 2020 Cruiser and was told it has full time operational cameras...for the life of me I can't find a switch to turn on a full time camera and have found  nothing in the manual.  I know the backup and side camera comes on when put in reverse or when using the turn signal.  Can anyone help?
Thanks
Engineerlt
Re: operating the back up cameras
« Reply #1 on: January 28, 2020, 07:43:22 am »
Hello
I have a 2017 that I leave the rear view camera on all the time, to keep an eye on the toad. I have the Pioneer radio/navigation system and just turn the rear camera on using the AV settings in the radio. One thing to realize is that the turn signal camera and rear view camera work only when the power switch on the dash is set to the coach batteries not house batteries. So you need to have the ignition switch on if you are not running the engine, as the cameras are powered from the coach battery. Also the turn signals are given priority over the rear view camera so when you use them the radio will switch to turn signal view, then briefly to the AV setting screen then to rear view camera.  I hope this answers your question.
Lance
