Battery Charger Question
  • 17 Replies
  • 23154 Views
biglegmax
  • 113
  • IntColor: lots
Re: Battery Charger Question
« Reply #15 on: September 10, 2019, 11:36:57 pm »
I agree with Gandalf, spend a little more go with the GPL 6CTS. I've got four, can't be happier, so far. They can be mounted , terminals inward, a little modification to the shelf, reduce the cobweb of wires PC creates with all the extra loops, totally unnecessary and really not to very high standards.
Doug
« Reply #16 on: September 11, 2019, 12:05:58 am »
When converting from two-12V wet acid, to two-6V AGM, In my heart & mind, I could not bring myself to rest them on their side.  So I removed the battery drawer, installed flat sheet metal, a battery frame, and then placed the AGMs inside upright.  The + and - terminal pegs are easy to access for external charging.  CLICK HERE for my write-up with pictures.
I am 100% convinced that a pair of 6V AGM batteries is the way to go.  AGM technology is one great advantage for maintenance-free and extra power.  6V batteries discharge and charge in unison which makes them perform much better than my experience with two different sets of two 12Vs.
Like biglegmax says, the cabling gets all cleaned up.
I don't know if Phoenix still has the rear tires splashing road debris on the batteries, but it was so with our 2007 2350 as shown HERE where I reworked the cables for a splash shield, which unknowing to me at the time made the perfect setup for AGM.
« Last Edit: September 11, 2019, 12:15:29 am by Ron Dittmer »
« Reply #17 on: September 12, 2019, 06:49:39 am »
What if battery shifts?
My earlier 12V batteries had extra room inside the original battery tray.  I placed a hardwood insert to keep them from moving around.  It worked perfectly.  Maybe he did something similar and we just don't see it.
