batteries
  • 11171 Views
garyg
  • 5
  • PurchDate: 07/2017
  • IntColor: brown
  • ExtColor: white
batteries
« on: August 08, 2019, 03:47:30 pm »
2007 2350, what size were the coach batteries when new ?? I have size 27 in mine now, time to replace
Cropduster
  • 124
  • PurchDate: 05/2015
  • ModelYear: 2002
  • IntColor: Brown
  • ExtColor: Brown
Re: batteries
« Reply #1 on: August 08, 2019, 04:22:00 pm »
If I recall correctly, the usual battery series identifiers are either "24" or "27".  Any battery shop will know what you need.  FWIW:  I always purchase a reconditioned battery for ~$50.  Comes with a two year replacement warranty and lasts four or five years.
BlueBlaze
  • 158
  • PurchDate: 06/2016
  • IntColor: birch
  • ExtColor: white
Re: batteries
« Reply #2 on: August 09, 2019, 08:11:49 am »
I'd upgrade to AGM's so you don't have to mess with the water level.  I used a pair of 12V Exide FP-AGM-24DP "dual purpose" batteries from Academy.
Re: batteries
« Reply #3 on: August 10, 2019, 07:30:12 am »
(cheer) (cheer) (cheer) Ron D has you covered (cheer) (cheer) (cheer)
Prepare to know 'all' about 2007 2350 best battery setup.  (nod)
 https://forum.phoenixusarv.com/index.php?topic=2092.0
Re: batteries
« Reply #4 on: August 10, 2019, 04:28:42 pm »
Thanks Volkemon for making my reply so easy.
Replacing our 12V lead acid batteries with 6V AGM batteries is still one of the best changes I made to our PC.
garyg, You and I have the exact same model and model year PC.  If changing to any type of sealed battery, I also recommend adding a battery splash shield. CLICK HERE to see pictures of what Phoenix provided in 2007, and what I later did to protect the batteries.  I have to admit, checking fluid levels was easier without the splash shield because the cables were better dressed.  But if having sealed batteries, the shield is great.  Having 6V AGM batteries has been the greatest.
« Last Edit: August 10, 2019, 04:37:49 pm by Ron Dittmer »
