I put hydraulic in the generator instead of oil but what should I do next
  • 21 Replies
  • 34473 Views
I am not running anything with contaminated oil that could have been a typo.
I thought that you
1) drained the crankcase for an oil change
2) Accidentally filled the crankcase with HYD fluid
3) Then you re-filled the crankcase with motor oil
4) Stopped to ask advice here
So, if the timeline is right, you have a crankcase with motor oil and an unknown quantity of HYD fluid it.  In other words, contaminated.
My plan is to run the Gen for 15 min with the new oil change then drain and replace with new oil and then run for a 30 min then put new oil once again hope that will work. I will let you know
So if I read this right, you are going to run the contaminated oil 15 min, drain, refill, run for 30 min, drain and refill with the 'final' oil that will remain until next change.
OK.... so now the contaminated oil will be run, and an additional oil change will be added.
 Some here proposed that you drain this oil, and put in new. Sure, there will technically be *some* HYD fluid in there forever, but the meaningful majority will exit with the 'first refill' oil being drained IMO.
But the prevailing advice seems to be 'RUN IT' with the contaminated oil, and assume there will be cleaning benefits from doing so. Then after running, drain the contaminated oil and refill with clean oil.  (WH)  different strokes, different folks.
Honestly, We cant hear your generator from here, so if the cleaning idea runs afoul, no problem!  Heck, back in the days of sawdust quieting a rear end, and oatmeal fixing a radiator leak, people would add all sorts of stuff to 'deep clean' their engine. Some still do! And empirical evidence supports they are right.  Being that there probably hasnt been any progress in oil technology or engine manufacturing in the past 40 years, you should be fine using the tricks of yesteryear, right?
My money is betting you will be fine either way.  I genuinely wish you the best of results, regardless of method. Those gensets are pricey.
romstead
  • 86
  • PurchDate: 3/30/19
  • ModelYear: 2011-2552
  • ExtColor: Sand
Update:  I’m still unable to work on the gen. Due to RV park rules about working on your rig. But My plan is to drain the oil in the gen. Refill run a short time then drain and fill again, run the gen a short time then drain and fill. Question does anyone with a 2011 Gen know if there is a oil filter on this Gen. IF so I will need to replace it correct ?
Man small
Why Fall?
Skies Call
That's All
I don't think any of us PC owners have a gas 4000 Onan generator with an oil filter.  Am I right?
My Onan manual does not mention an oil filter.  Scheduled maintenance under normal conditions is as follows.
- oil change every 150 hours or once a year
- replace the air filter every 150 hours
- replace the spark plug every 450 hours
- clean the engine cooling fins every 250 hours
- replace fuel filter every 450 hours
- clean out the soot from the muffler spark arrestor every 50 (fifty) hours
Yikes!  I am way overdue on that last one.  I never heard of that maintenance before.
« Last Edit: July 23, 2019, 12:10:49 am by Ron Dittmer »
romstead
  • 86
  • ExtColor: Sand
Update ://
1. I drained the Hydralic fluid before starting the Gen (Thankl goodness)
2.Added the correct 30wt oil
Let it stand or sit in the Gen. For about a week then but did not run the Gen
3.drained again and put new oil in and ran The Gen with no load for 15min with no problem
4.drained yet again put in new oil,and ran under load 30 min with no problem
5.I hope All is well next test is to run for 2hr under load
Man small
Why Fall?
Skies Call
That's All
romstead
  • 86
  • ExtColor: Sand
Re: I put hydraulic in the generator instead of oil but what should I do next
« Reply #19 on: September 09, 2019, 10:04:06 pm »
Up date all is well with the generator with 5-8 hours on it since the last lol change all i
Seems well
Man small
Why Fall?
Skies Call
That's All
« Reply #20 on: September 10, 2019, 05:19:38 am »
Excellent news! One more "learning experience" on your road to adventure.
romstead
  • 86
  • ExtColor: Sand
Up date:
I have put about 15 hours on the gen with no issues all is well . Thanks for all the input and great stories of how and what to use to clean up the engin to make it run better
Man small
Why Fall?
Skies Call
That's All
