Voltage Regulator Replacement
  • 14040 Views
thrutraffic
  • 87
  • PurchDate: 9/1/2018
  • IntColor: Sand
« on: June 16, 2019, 02:20:28 pm »
Cummins Onan RV QG 4000
Where is the voltage regulator?
Can it be tested/replaced without pulling the generator out a PC 2551?
  • 686
Re: Voltage Regulator Replacement
« Reply #1 on: June 16, 2019, 04:28:01 pm »
Here’s the Onan service manual:
https://www.rvwithtito.com/download/Onan4000MaintenanceManual.pdf
It appears to be a relatively easy task.
Location- see fig. 6-2 in sect. 6-3
Test procedure - see sect. 9-12
Before getting into that try using the carburetor altitude adjustment knob to lower the engine rpm’s.
« Last Edit: June 16, 2019, 04:59:45 pm by CalCruiser »
thrutraffic
  • 87
  • IntColor: Sand
« Reply #2 on: August 01, 2019, 08:41:12 pm »
UPDATE:
It's the EMS not the generator voltage regulator. If I take the EMS out of the picture the generator voltage stays around 123v. I I enable the EMS the generator voltage stays at 123 but the EMS will report the same for maybe 15 seconds and then jump to 135 and then trips out disconnecting the power. Turning off the EMS then routes power to the distribution panel again.
Another thing to note: my last two trips I made I noticed the EMS reporting 135v and often tripping out. I was complaining in my head that it was the RV campgrounds I was staying at. Now I know that wasn't the case.
  • 686
Cropduster
  • 124
  • PurchDate: 05/2015
  • ModelYear: 2002
  • IntColor: Brown
  • ExtColor: Brown
« Reply #4 on: August 02, 2019, 10:56:01 am »
The original electrical converter on our PC2100, a Magnatex 6332, was based on an analog design.  As it accumulates time and use, the unit is known for over-charging the RV's 12v battery.  I replaced this with a Progressive Dynamics PD4635 unit.  Also replaced the stock 12v fuse block with an updated one which, if a fuse is tripped, will display an red LED light Located directly below the blown fuse. The upgraded converter maintains a better battery charging cycle, as well as preventing an over-charge.  Along with added protection for 12v electrical devices operating in the RV.  The swap took several hours, most of it being the time it took to wire a jumper onto the positive cable.  The original one being too short to reach the contact on the new converter.
« Last Edit: August 02, 2019, 11:06:37 am by Cropduster »
