Rear stablelizer not coming done consistently
  • 9707 Views
romstead
  • 86
  • PurchDate: 3/30/19
  • ModelYear: 2011-2552
  • ExtColor: Sand
« on: June 02, 2019, 09:25:10 pm »
I have a 2011 2552 and I have noticed the rear and occasionally  one of the front leveler leveler does not come down at the same time as the one across from it does. Is there something I can do to help them drop at the same time and what do you use for a dry lube,?  and I could use some maintance tips as well.
Update: I have been reading up on my HWH Lever system and will be checking the hydraulic level and do some cleaning, I have so much to learn about all fo the systems on my rig. I’m still on the steep learning curve.
« Last Edit: June 04, 2019, 08:05:34 pm by romstead »
Man small
Why Fall?
Skies Call
That's All
Re: Rear stablelizer not coming done consistently
« Reply #1 on: June 04, 2019, 08:12:58 pm »
If you have the manual, or the online version check what they recommend for oil / grease on the cylinder shafts.  They might need cleaned and oiled.  It could also be a lack of fluid as you say.  If they are nice and shiny and clean I would guess the system might need fluid.  If they are not shiny then look into cleaning / greasing.
RheaNL
  • 220
  • PurchDate: October 4, 2012
  • IntColor: Dusk
  • ExtColor: Dusk lower
« Reply #2 on: June 10, 2019, 09:58:11 pm »
Yes, you need to keep the hydraulic fluid level up.  However, your problem sounds more like dirt. Whenever we've been on dirt roads or one disaster on a dirt road that had just been sprayed with mag chloride, I put the HWH levelers down, scrub them within abandon until they sparkle, then spray with T-9.
https://www.amazon.com/BOESHIELD-Corrosion-Protection-Waterproof-Lubrication/dp/B001447PEK/ref=sr_1_1?keywords=t-9+spray+lubricant&qid=1560218005&s=gateway&sr=8-1.
So far (almost 7 years and a lot of dirt roads), and they are still working great.
