For the TRX wanabes
  • 30 Replies
  • 34626 Views
Re: For the TRX wanabes
« Reply #30 on: April 03, 2019, 08:42:58 am »
FYI - a wind generator mounted directly to a house or RV will relay the vibration and noise directly into that structure. It is also greatly affected by objects around it as the wind swirls over and around hills, trees, cars, RVs etc. Wind generators like steady, smooth air flow. That said, the reduced power you get from a low mounted wind generator is at least something.
Thanks for the info on the flex panels. If their performance is comparable to rack mounted panels they would be preferable for an RV as that would reduce wind drag.
