Satellite TV
  • 11 Replies
  • 20159 Views
ron-n-toni
  • 191
  • PurchDate: 8/3/2017
Satellite TV
« on: November 30, 2018, 06:26:53 pm »
Headed for Florida on the 15th for 2 to 3 months to let double knee replacement heal. Longest trip ever. We have been thinking of getting satellite TV but have many questions. We see Dish has a program were you can call to turn it on and off. Is Dish or Direct better. How about antennas, roof top or carry out.  I see some info that you can only get local stations on the western satellites; true or false. Any thoughts on systems, equipment, or where to buy. Thanks. :help
TheLuvShack
  • 143
  • PurchDate: October 2016
Re: Satellite TV
« Reply #1 on: November 30, 2018, 08:58:53 pm »
If you have Dish or Direct at home, I'd check with them first. You might be able to add a receiver for a small fee.I went with Dish for RV. Easy to turn service on and off either by phone, app or text. Satellite (antenna) can be quite large. They're are not heavy but take up a lot of space. I pull a towed so I just put in there. A roof mount could increase the height of the RV. Many models will recieve western and eastern satellites. That's one reason why I chose the Winegard Pathway X2. A free standing unit with auto search and the ability to hook up two TVs. You'll also need one or two recievers like a Wally or something similar and a length of coax. Hooking it up is simple if you have a two inputs on the outside of your PC. One marked CABLE the other marked SAT. If you just have one input marked CABLE, hookup becomes a bit more complicated. I purchased a Pathway X2 and a Wally package from Amazon Warehouse for $285. This was supposed to be a used or reconditioned unit. When I recieved it, it was in factory packaging and looked new. It works perfectly. I'd post a clicky if I knew how. Go to Amazon homepage. In the search box there's a drop down arrow. Click on it and select Amazon Warehouse. Enter the satellite you want. Hit search. Good luck with those new knees!
jam4travel
Re: Satellite TV
« Reply #2 on: November 30, 2018, 10:24:04 pm »
TheLuvShack posted very good information.  Another choice you will have to make is whether you want standard or standard & HD reception.  Not all satellite dishes offer both standard & HD.  You might want to read the following URL links:  1)  "https://www.reviews.org/internet-service/rv-satellite-internet-and-tv-antennas/"  2)  "http://www.winegard.com/carryout-g2".  I would contact both Dish & Direct TV and find out what type of packages they offer that in include local channels for full time RVers and make sure the satellite dish you choose can receive their packages.  I have always had direct tv & get my satellite signals from satellites 99º, 101º, and 103º with an east coast feed for local channels ( I have the roof mount Winegard TRAV'LER satellite dish-standard & HD).  If you get a roof mount unit it will cost more because of the installation cost, and if you ever get stuck under a tree you won't get any reception.  Portable satellite dishes are more flexible if you are ever in a RV park with obstructions. You may not need two RF coaxial cable external connectors if you get a portable satellite dish and if your coach as RG6 Coaxial Cable installed and don't want to connect to a park cable service.   Best wishes in finding a satellite system and a satellite provider, and in the recovery from you knee replacement surgery.
« Last Edit: November 30, 2018, 10:26:58 pm by jam4travel »
Re: Satellite TV
« Reply #3 on: December 01, 2018, 04:51:12 pm »
We use Dish, we can turn it on and off.  I have used both roof mounted and carry out antennas over the years.  The biggest issue is where you are going to park the RV.   If you have a rooftop, you can't have any trees, buildings or the like between your antenna and the satellites.  Since it seems you are going to be at a single site for a few months, if you have a rooftop antenna, you must make sure you have a clear view towards the satellites.
With a carry out, the biggest problem is where to store it while you are traveling.  They are relatively large and won't fit in any of the inside or outside storage areas.   The next issue is where the cable and the tripod go and finally how to get the cable from the outside to the inside of the RV where the satellite receiver is.
None of the issues are insurmountable but they require planning.
Currently, I use a rooftop but I don't stay anywhere for long periods of time.  I am also not "addicted" to TV, so no biggie if I park in a spot where I can't get a signal.  There's always plain over-the-air TV.
The choice is yours, just be aware of the requirements for either type of antenna.
Both types come with "autolock" where all you do is turn the antenna on (while attached to your receiver) and the antenna self-aims to locate the satellites.
TzrNPeg
  • 83
  • PurchDate: 9/27/2018
  • IntColor: Greystone
Re: Satellite TV
« Reply #4 on: December 01, 2018, 07:54:03 pm »
I have the Dish carry out and it fits under the driver's side bed.
Peg
BlueBlaze
  • 158
  • PurchDate: 06/2016
  • IntColor: birch
  • ExtColor: white
Re: Satellite TV
« Reply #5 on: December 02, 2018, 05:24:10 pm »
Seems cheaper to just get a Roku or Amazon Firestick and an unlimited data plan for your phone.  Turn on your phone's "hotspot" feature, and between your antenna and the internet, you'll have more to watch in your RV than you do at home.
We "cut the cord" to DirectTV satellite at home two years ago and wouldn't go back now if you paid me.  In fact, you can even get DirectTV over the internet for $35, complete with ESPN and the locals and even a built-in "cloud" DVR.  The only thing you lose is the 150 foreign language channels that you never watched anyway.  And it only costs $5 to add HBO!
lmichael
  • PurchDate: May 15, 2012
  • IntColor: Sterling
Re: Satellite TV
« Reply #6 on: December 02, 2018, 08:37:00 pm »
We take our directv from home when we travel so no additional cost or having to call to turn on off.  Don't get network stations, but they're usually available with antenna.   Keep in mind that directv is going away from satellite to streaming in 2019 which can cause problems in remote areas.
Re: Satellite TV
« Reply #7 on: December 03, 2018, 10:13:53 am »
It has been a number of years since we stayed in an RV park with full hook-ups, so this question is a bit ignorant.
When staying in RV parks over the winter, I thought such places included CATV.  It would seem to me CATV would be your best option rather than messing with a dish.
If CATV is not available, is roof-top antenna TV so poor?
Re: Satellite TV
« Reply #8 on: December 04, 2018, 07:50:11 pm »
Ron,
The parks we stay at over the winter are not usually full hook ups.  Many of us stay at federal parks, state parks, county parks and some even boondock for weeks at a time.  Spending the winter in an RV is like being on a summer vacation but in “winter” months.  Totally AWESOME for three months!
Sue
Re: Satellite TV
« Reply #9 on: December 04, 2018, 11:43:46 pm »
Ron,
Sue
Hi Sue,
Do government owned lands allow you to stay there for so long a period of time?
Re: Satellite TV
« Reply #10 on: December 05, 2018, 11:09:46 am »
Ron,
It varies, some allow 2 weeks, some allow 4 weeks and some may even allow more.  We book in advance and move as necessary.  It’s great to go to different parts of the state and meet different people and many times explore new areas.
Sue
Re: Satellite TV
« Reply #11 on: December 05, 2018, 01:39:45 pm »
Ron,
Sue
Ah, I get it.
