Anyone with Vittrifigo refer?
  • 33 Replies
  • 33925 Views
No
  • 72
Re: Anyone with Vittrifigo refer?
« Reply #30 on: September 21, 2018, 02:58:05 pm »
Very interesting reading. I am manually changing the mode switch to AC when parked with shore power, & LP when moving. The Auto position does not appear to work. Bad board?
We rerouted our trip home from Duluth to Elkhart to have the Norcold absorption worked on. From watching the tech, it appears Phoenix did not install insulation above the fridge or install a baffle to direct the heat off the top to the exterior vent. We noticed a very slight increase in performance. On a setting of 9, we barely manage to keep 38°-40° in the lower compartment with outside air temps of 60°-75°.
The only time we use the inverter is power a small crock pot while driving. (Thanks for the tip Mrs Robbins, Earl's wife!)
Steve
hutch42
  • 246
  • ModelYear: New TRX
« Reply #31 on: September 22, 2018, 03:12:59 pm »
Denny & Barb
How long have you been using the Danby fridge.  Any issues with it so far?
Hutch
HenryJ
  • All ready for the road
  • ModelYear: 2016 / 2910T
  • IntColor: Hickory (light)
  • ExtColor: graystone
« Reply #32 on: September 23, 2018, 08:59:45 am »
Well in 2 weeks I get to see how long it takes my Norcold that will run on some kind of electric or lp gas , will take to get  up to cold. Before this it was never off except to defrost. And it would get cold enough to freeze things in refrig. It is 2016  2910T model RV. I just hope it works... My handyman went to heaven so he is in real over see-er mode... and now I have to keep things running and pray a lot maybe.
Patricia
Denny & Barb
  • 328
  • Medicine Bow, Wy.
    • Weather at my home
  • PurchDate: 4-08-2012
« Reply #33 on: September 23, 2018, 09:22:49 am »
Denny & Barb
Hutch
Hutch, only had the Danby since middle of April. So far no issues. Works like the frig in our house. Gets really cold fast. Found running it on #4.5 of possible 8 or 9, is plenty cold.
Denny and Barb
