How long in Elkhart for delivery
  • 9 Replies
  • 17797 Views
ErinS
  • 41
  • PurchDate: 04/2018
  • ExtColor: Desert Sand
« on: January 16, 2018, 09:53:49 pm »
I am scheduled to pick up my new 2552 on 4/2/18, how long should I plan to stay in town to resolve any issues?  What kind of issues have others had to deal with on delivery?  I have read on other posts that PC does not do a final inspection, is this true?
Re: How long in Elkhart for delivery
« Reply #1 on: January 16, 2018, 11:52:41 pm »
Hi Erin and welcome.  One of those posts was likely mine and I would like to clarify that a bit.  In my case our pickup was rushed because we had to be on the road, that was on me not PC.  But I felt lots of things were missed that should have been caught.   However, saying "PC does not do a final inspection" is certainly untrue.  They do have a final inspection but perhaps it is not as thorough as we might wish.  And with new owners I hope more attention is being paid to this.  And this was my first RV, so I would have caught a lot of those items on the walk through if I knew what to look for.
However, buying an RV is not like buying a car.  The customer must take a certain amount of responsibility for checking and making sure things work to their satisfaction.  Often that is called a walk through or pre delivery inspection.  Earl or Kyle will do that on your coach, but they will not catch everything, and some things are impossible to catch until the coach has been lived in a bit.  Not saying that is right or wrong, it is just the way it is.
To answer your question:
Plan on spending a minimum of two nights locally before driving off into the sunset.  The area has lots to see anyway, so enjoy it.
Check everything:
1) Every door, latch, knob, screw, switch and valve. Both inside and outside.
2) Check all of the electric receptacles both 120 and 12 volt and USB
3) Check all of the plumbing.  Fill the tanks and dump the tanks.  A couple of times.  Check all of the faucets.  Check the water heater both electric and LP.
4) Check all of the appliances.  Including the furnace, heat pump, water pump, air conditioning, stove, microwave, TV, generator and so on.
5) Drive the rig in different kinds of conditions, both traffic and highway.  Get it up to speed on the interstate and get a feel for it.
6) Use your order sheet and build sheet and make sure all options you ordered were installed.
An RV is a complex set of systems designed to work in a variety of different situations.  And you have to test things both when plugged in and when not plugged in to shore power because the rig will react differently.  And under current conditions and under other extremes.  One example from my coach was that the air-conditioning did not work.  I tested it at pickup and the compressor ran and the fan came on and it was cold.  As in it was 20 degrees outside so of course it was cold.  When we got to California it sounded exactly the same but no cold air.  Replaced under warranty.  Would have been replaced at the factory but I assumed since it ran it would work.  And so did the folks at PC.  Some things are very hard to test.  In April it might be warm, but test the furnace anyway.  And the heat pump, or heat strips as equipped.
Take a note pad with you and when you find something that either does not work or you do not understand write it down.  Take that list back to the factory the next day and go over it with them.  Some things will need fixed or adjusted, some things might be just that you need more explanation.  Let them go over your list, then go back to the campground and cook dinner.  Check things again, get your gear stowed.  Make a new list and repeat the next day.
ErinS
  • 41
« Reply #2 on: January 17, 2018, 08:55:41 pm »
Thank you so much for the input.  My folks who are longtime RVers (2 class As), will be joining me on delivery.  Dad has gotten me a checklist that is very thorough, but not PC specific.  Advice for brand owners is always good.
No
  • 72
« Reply #3 on: February 14, 2018, 05:52:15 pm »
Erin,
We will be picking up a new 2552 the first week of March. The plan is to do the walk-through in the morning, drive to the airport to return the rental, fill with gas and propane, put on some miles around the area, return to PC for the evening, and then head south the next day unless there are punch list items to remedy. Hopefully the weather cooperates and our maiden voyage will be smooth sailing!
Thanks for the list Jatrax, I am building a list that now includes soaping down the tire valves to check for leaks after reading a post on Valve Extenders.
Steve
« Reply #4 on: February 14, 2018, 06:16:24 pm »
Steve,
Depending on who you rent from there may be a local office to return the rental to.  I'm not sure who we rented from (maybe Enterprise) but we returned it to a lot maybe 5 miles from the factory.  Kyle followed us over and drove us back to the factory.
We flew into Chicago, rented a car and drove to Elkhart, dropped the car in Elkhart.  Ask Kyle or Earl, they can help you with that.
bhgareau
  • 111
  • PurchDate: 05/12
  • IntColor: dusk
  • ExtColor: sterling
« Reply #5 on: February 14, 2018, 09:57:45 pm »
We flew into O'hare and found that we could take a limo for less than the cost of renting and dropping off in Elkhart. You might consider checking that out.
No
  • 72
« Reply #6 on: February 15, 2018, 10:35:37 am »
Great suggestions, thanks!  I get a really good deal on National through my company so we pick up at O'Hare then drop at South Bend airport. We'll use the rental to pick up some supplies like food for the trip home. We'll be shipping a box up there with some tools, clothes, linens and such. The trip to drop the car will be a good 50-60 mile shake down on delivery day.
Steve
mhoecker
  • 57
  • PurchDate: May 14, 2018
« Reply #7 on: February 15, 2018, 06:37:51 pm »
Erin,
Steve
Steve, if you don’t mind me asking, when did you order?  Our 2552 is under construction but we haven’t been given a pickup date yet. Admittedly, we asked for a few mods and additions.  We order 12/29.
No
  • 72
« Reply #8 on: February 16, 2018, 03:32:27 pm »
M,
The purchase order is dated 10/24. I know that seems ages ago yet the plant shuts down for 2 weeks in December, they built 3 (?) coaches for the Tampa show and then had to transport them down and back so Earl told me then it would be sometime in Feb for delivery. This month has just too much going on so we are going up Mar 5. We also had several changes/options plus full paint so that added some time.
I really did not welcome the idea of delivery in January or February anyway so this works out well for us.
Steve
ErinS
  • 41
« Reply #9 on: February 16, 2018, 04:54:56 pm »
Madonna,
I ordered mine in late October, but specifically asked for a delivery date of 4/2, since my folks are traveling from the West Coast to help me take delivery and I did not want them to encounter snow on their travels.
Erin
