Poll
What weight oil do you use in your Triton V10?
0w-30
0w-40
5w-20
5w-30
10w-30
10w-40
Something else
Let's talk Oil
  • 22 Replies
  • 83955 Views
Desert Dave
  • 18
  • PurchDate: 10/10/2020
  • IntColor: brown/cherry
  • ExtColor: brown
Re: Let's talk Oil
« Reply #15 on: November 22, 2020, 10:29:37 pm »
I'm glad that I found this topic.
We just drove to NY to purchase our 2011 3100. It was about 3500 miles back home, with side trips and I needed to add a quart at 3000 miles. The seller had the vehicle serviced just before we picked the PC up, and I checked the oil (kind of anal that way, I guess?) when we left. They used Motorcraft oil. The V-10 was working through the hills that the east coasters call mountains, and we were pulling a toad (2011 Ford Escape) on a tow dolly. I have been driving a diesel for the past 14 years, so I really had to get used to the higher revving V-10. Anyway, sounds like this oil consumption is "normal" when the V-10 is working this hard?
A side topic to the oil conversation should be one on oil filters. I saw a U-tube video where several kinds of filters were cut apart and the difference between filter material inside of the filters was disappointing, to say the least. The Fram, which I have been using since High School Auto Shop Class were the most disappointing. The NAPA Gold and the WIX filters contained the most filtering material. NAPA Gold is made by WIX.
A good friend of mine worked at the county garage where they serviced all county vehicles including police cars. He said the black & whites were considered extreme duty vehicles; they are driven by different deputies every day, sometimes at high speeds for long periods, but hours and hours of idling almost every shift. They switched to full synthetic, and even with the harsh usage, they changed oil only every 7500 miles. But, they used good filters. Just my 2 cents.
zolman
  • 109
  • PurchDate: 12/29/2021
  • ExtColor: white/gray/black
Re: Let's talk Oil
« Reply #16 on: July 04, 2023, 10:56:30 pm »
I have two friends who are bus mechanics. They only use 5w30 synthetic blend in all their V10 buses, some with well over 250K miles. They buy it direct from from ConocoPhillips in 55 gallon drums. ConocoPhillips makes Motorcraft and they claim it is the same as what Ford specs. They claim it is a superior oil for the V10 compared to other brands.
Re: Let's talk Oil
« Reply #17 on: July 05, 2023, 12:02:55 am »
Reference Zolman's message above.  Yes!  At least by 2019, Ford specifically recommended their synthetic blend in 5w-30 for the V-10.  I researched this thoroughly before my first oil change on my new unit back in 2019, and found multiple sources that confirmed it.  I didn't find WHY they want to use the synthetic blend instead of full synthetic, but that was definitely their recommendation.
Because of that, I have continued to use the Ford Motocraft 5-30 synthetic blend oil in my unit.  Without that recommendation, I would likely have gone full synthetic in 5w-20 as I do in my other vehicles.
Re: Let's talk Oil
« Reply #18 on: July 09, 2023, 06:32:33 pm »
I have used 5w-30 full synthetic in every vehicle I have owned since as long a Mobil 1 has been available.  All of them, including 3 RV's on Ford cutaway chassis with V10s in them and several hundred thousand miles between the 3, and never had to add oil between oil changes (about every 8 to 10 thousand miles.  I use Mobile 1 or Pennsoil full synthetic in them.
Re: Let's talk Oil
« Reply #19 on: July 09, 2023, 06:38:25 pm »
My 2014 PC chassis, Ford reccomends 5w-20.  As I said above, I have always used 5w-30.  In the 60's and 70's I used nothing but Pennsoil "racing blend" 10w-40.  Even in below 0 degrees Fahrenheit.
Greg B
  • 12
  • PurchDate: February 2015
  • ExtColor: Desert Sand
Re: Let's talk Oil
« Reply #20 on: November 27, 2023, 03:43:44 pm »
I use 5W-20 per manufacturer specs.  I use Amsoil full synthetic in every thing I own.  My PC has almost 35K miles on it and I have never had to add oil between changes.  I usually go 5K between changes unless on a longer trip.  Just got back from a 6300 mile trip and the oil was still clean...changed it anyway.  As a side note a use Amsoil V-Twin synthetic in my Harley and have noticed it shifting smoother and using less oil.  Many of the Harley repair shops recommend the Amsoil.
Amsoilman
  • 71
  • PurchDate: 2024
  • IntColor: Grey
  • ExtColor: White Grey
Re: Let's talk Oil
« Reply #21 on: August 19, 2024, 08:05:27 am »
I was an AMSOIL Dealer for 18 years so I drank the Kool-Aid. I use Amsoil and all my equipment and I just changed the oil in my 2016 Phoenix cruiser 3100 using 5/30 as recommended. I use the Amsoil ASL and plan on changing it once a year. I also use the Amsoil filter. I also use an injector cleaner as recommended by Amsoil as I know it does a great job of keeping the injectors clean. In my diesel truck I also use an injector cleaner. Amsoil does cost more but they make great products .
flei
  • 89
  • PurchDate: 03/2020
  • IntColor: ?
  • ExtColor: ?
Re: Let's talk Oil
« Reply #22 on: August 19, 2024, 09:31:32 am »
2007 PC 2350.  104,000 miles through all types of North American terrain and weather.  I try to change the oil (and filter) every 5k miles and use 5w-20 full synthetic.  I don't believe the "our oil is the best" advertising hype so at home I use whatever brand happens to be on sale (if I'm on the road when a change is due then I just go to some "quikee-lube" type place and they use whatever they use). Nothing beyond routine maintenance has been done to the engine. Never have needed to add oil between changes.  These V10s are known to be durable truck engines.
« Last Edit: August 20, 2024, 08:08:04 am by flei »
