Heat strip turns on when turn on furnace.
  • 12483 Views
TheLuvShack
  • 142
  • PurchDate: October 2016
« on: October 31, 2017, 09:31:31 am »
I have a 2012 3100 with Dometic thermostat and Duo Therm AC with heat strip. When I select the furnace and turn it on, the heat strip comes on too. Both run at the same time. I don't remember this happening before. Is this normal or do I have a problem? Thanks, Daryl
HomeSweetRoam
  • 11
Re: Heat strip turns on when turn on furnace.
« Reply #1 on: October 31, 2017, 01:21:37 pm »
Try putting your fan on Auto.
HenryJ
  • All ready for the road
  • ModelYear: 2016 / 2910T
  • IntColor: Hickory (light)
  • ExtColor: graystone
« Reply #2 on: October 31, 2017, 05:37:56 pm »
That is not normal at all. We have used our units with heat strips , we have 2 and it was cold enough. However if we used the furnace
it was just the furnace and seemed to work well. Have not had a lot of these uses so we are close to getting a try out for this year
soon. Hope you get it all settled. You can call the plant and see who can give you the scoop. Good luck. Regards, P
Patricia
TheLuvShack
  • 142
« Reply #3 on: October 31, 2017, 06:16:34 pm »
Thanks for the responses! I just winterized and put it in storage for the winter. I do know that my fan is set on "high". When we head South, I'll set fan on "auto" and try again.
Daryl
« Reply #4 on: November 01, 2017, 10:58:27 am »
Luvshack.....I hoping more owners will chime in to help Loveshack with his issue.....I know there is a setting in that thermostat that will prevent the heat strip from coming on with the furnace but it has been to long since I had my PC (his!) to recall what and where the toggle is...I know it does have something to do with the "auto" setting.  Thanks, RAG
JackD
  • 231
  • PurchDate: 2017 (latest)
  • Model: 2350 Sprinter
« Reply #5 on: November 04, 2017, 12:49:30 pm »
Wethompson1 has a good point - set the fan to Auto.
Jack
TheLuvShack
  • 142
« Reply #6 on: December 15, 2017, 08:13:29 pm »
Set the fan to "auto" is the correct answer! Picked up the PC from storage today and furnace works just fine. Thanks to all !!
