Slide Awning Stretched
  • 1 Replies
  • 7389 Views
Dave R
  • 24
  • PurchDate: Delivered 12/16/16
  • ExtColor: Desert Sand Full Body - modified
« on: June 15, 2017, 06:50:39 pm »
Beware leaving the slide- out in high winds. - awning is not covered under warranty.
My slide awning on a 2351 recently got stretched in high winds. With the slide out, the awning hangs loose (1" down) on one side and flaps in a mild breeze.  Does any one have suggestions how to make that side tighter?
Thanks Dave
Re: Slide Awning Stretched
« Reply #1 on: June 16, 2017, 07:01:03 am »
Hi Dave,
With our regular awning, once due to high winds I had to unroll the entire amount of material, then roll it back onto the spool to get rid of the uneven condition you describe.  Maybe that will work for you with your slide out awning.
