Flip Up Counter issue
  • 16 Replies
  • 21694 Views
HenryJ
  • All ready for the road
  • ModelYear: 2016 / 2910T
  • IntColor: Hickory (light)
  • ExtColor: graystone
Re: Flip Up Counter issue
« Reply #15 on: August 10, 2016, 08:14:05 pm »
The flip down extension is wood an does not match the counters. I think it will not get much use since it blocks access to back of coach completely. So sorry to hear about the glue softening and  slippage. Hope you can fix or replace. We have had 2 weeks to find out thngs and the Forum has revealed things we wish we knew in advance. Great Helpers.  Patricia
Patricia
« Reply #16 on: August 11, 2016, 06:26:21 am »
The counters are in different places in different models. They all block something when up which is why they are designed to be up temporarily. The flip up counter in the 2552 is across the house door. I have been known to sqeeeeeze by or crawl under if it is set up and loaded with something and I need to get into the house. The cab doors would give easier access but we keep those locked.
