WATER OVERFLOW?
  • 15 Replies
  • 22336 Views
ron-n-toni
  • 191
  • PurchDate: 8/3/2017
Re: WATER OVERFLOW?
« Reply #15 on: July 27, 2016, 08:42:49 am »
While at the factory picking up my 2351 after some work, Bob went to fill the water tank for us and found it wouldn't fill the tank. They replaced the valve. He told us that we should not change the position of the valve when it is under pressure. There are o'rings inside the valve that can be damaged when the selector is moved under pressure. I have done so since and have not had any problems since. Just food for thought.
