110 Volt Power Questions
  • 20 Replies
  • 28277 Views
JOHN
  • 50
  • PurchDate: pickup 10/2016
  • ModelYear: 2016 - 2351 Ford
  • IntColor: Nightscape
  • ExtColor: Standard Paint
Re: 110 Volt Power Questions
« Reply #15 on: April 13, 2017, 05:11:08 pm »
Ron,
With that splitter will I plug in as usual with the 30 amp connection and I will tie in the 110 v to the female end of your splitter example?
« Reply #16 on: April 13, 2017, 05:14:12 pm »
Ron,
Ooops!
This is the one you want.  Same thing but male/female in reverse.  Sorry about the mixup....a senior moment.  I get them more frequently as I get older.   :)
JOHN
  • 50
« Reply #17 on: April 13, 2017, 05:39:16 pm »
Got it thanks.
« Reply #18 on: April 13, 2017, 07:43:06 pm »
Actually what you should get is this and a 25' heavy duty 15amp extension cable.  Otherwise you'll have another 30' of 30 amp cable plus an extension cord and/or a heavy adapter to plug into the 110v outlet.
Just a suggestion.
https://www.amazon.com/dp/B0185FGKXW/sr=8-30/qid=1492126808/ref=olp_product_details?_encoding=UTF8&me=&qid=1492126808&sr=8-30
« Reply #19 on: April 13, 2017, 08:00:12 pm »
It is best if you can get to the power peg with your 30 amp cord.  Then use an adapter right there at the peg.  If your PC provided cable is too short, it's better to have a 30 amp extension.  This way you are better equipped for other situations when 30 amp service is available but too far away.
I had bought two 25 foot 30 amp extension cords from Menards on clearance for $15 each.  It's not a good idea to get too long like that, but it's much better than a 15 amp extension cord of the same length.  In all our travels, I used one extension cord one time, in Black Canyon Of The Gunnison NP.  They actually had a power peg in the camp ground, very unusual for a national park.  But it was not close enough to use the PC cord alone.  I also recall there were a few power pegs in the Badlands NP campground. but again, too far for one 30 amp cord to reach.
Come to thinking about a quick remedy adapter, Walmart sells a real small adapter with no cable in between, just like this.  It is very affordable and readily available.
« Last Edit: April 15, 2017, 09:00:19 am by ron.dittmer »
« Reply #20 on: April 14, 2017, 03:40:50 pm »
Check reviews before you buy any adapter. Some overheat and some don't. We carry the little guy that Ron showed but haven't used it yet.
