What Is That Banging I've Been Tollerating For The Past 3 Years?
  • 15 Replies
  • 46885 Views
gl1500
  • PurchDate: May. 2014
  • ModelYear: 2551/2014
  • ExtColor: Cafe'
Re: What Is That Banging I've Been Tollerating For The Past 3 Years?
« Reply #15 on: May 08, 2011, 08:46:42 pm »
We were in some heavy winds, both driving and parked, and heard a very loud banging.  Remembering what people had said about the antenna, I climbed up on the ladder to check it.  Guess what, it was not moving, but the banging was still there.  After searching for the location of the noise, I finally located it.  On our 2552, and many other units, there is a large steel plate that acts as a heat shield between the generator and the propane tank.  It was loose at the securing screws allowing it to swing in the wind and bang against the tank.  A check with PC and found it was not needed anymore because the extra foot of length from the 2551 to the 2552 gives plenty of clearance.  So I just took it off and sealed the screw holes.  No more noise.
