Hot Water by pass
  • 9353 Views
jas
  • 58
  • PurchDate: 5 20 14
  • ExtColor: Desert Sand
Hot Water by pass
« on: June 07, 2015, 10:28:41 am »
Help  On a 2910T where  is the hot water tank bypass valves?? Not under the sink. Just flushing the system getting ready for a trip to Stow Vt. Will go thru Pa. to get there.
        hope to over night in Lancaster county. What is a good RV park?  JAS
Re: Hot Water by pass
« Reply #1 on: June 07, 2015, 11:08:30 am »
Jas....the valves are under/behind the bottom draw in the kitchen.  The little levers on the draw slides need to be pushed one up one down and the draw slides out and you will see the three valves for the bypass as well as the two low water drains.  Have fun visiting new england....come to NH and spend some money!!
palmettorose
  • 24
  • PurchDate: February 21, 2015
« Reply #2 on: June 07, 2015, 11:55:29 am »
JAS according to the walk thru I had with Earl when I picked up our 2910d, it is on the passenger side opposite the bed. Small door and you have to take the hinge off to get into it. I personally  have not removed the door but that was where I was told the bypass was located.
jas
  • 58
« Reply #3 on: June 07, 2015, 03:08:21 pm »
Thanks  It was opposite the bed behind the door  jas
« Reply #4 on: June 07, 2015, 03:39:44 pm »
When we traveled through that area we stayed at Thousand Trails in Lebanon, PA.  It is a membership park but they did allow others to stay and we paid Passport America rates which was $22 a night.  This was last September.  It is a beautiful, clean park centrally located between Hershey and Lancaster.
jas
  • 58
« Reply #5 on: June 07, 2015, 05:24:07 pm »
Thanks  Will give it a try.  jas
