Low Cost Macerator Pump Replacement (Saved A Pile Of Money)
  • 28 Replies
  • 100621 Views
Re: Low Cost Macerator Pump Replacement (Saved A Pile Of Money)
« Reply #15 on: April 16, 2017, 04:23:33 am »
Ron:  This is an older post, but you referenced it recently in a separate later post.  I was wondering if you had ever gotten around to determining where the greatest noise emanated from, the piping or the motor/strap/frame?
« Reply #16 on: April 16, 2017, 08:14:14 am »
The loud macerator motor noise most definitely resonates through the black PCB waste pipe.  Not the strap that holds the macerator.  The replacement macerator resonates much less than the original one due to it being new.  I am confident it will get louder over time and wear just like the original one did.
Dale and Cindy
  • 35
  • PurchDate: July 2014
  • Model: 2350 Sprinter
« Reply #17 on: July 06, 2017, 09:48:42 pm »
Your replacement pump is still working, yes?
« Reply #18 on: July 06, 2017, 10:12:35 pm »
Yes, it's working fine as of our last time out which was last fall.
« Reply #19 on: June 04, 2018, 08:35:59 pm »
Our Seaflow macerator still working great as of September 2017
thrutraffic
  • 87
  • PurchDate: 9/1/2018
  • IntColor: Sand
« Reply #20 on: July 04, 2020, 03:32:08 pm »
My Thetford 70428 motor froze.
Can anyone quote the SeaFlo model numbers and detail info for the SeaFlo unit in this post? They’re too blurry for me to read.
TIA
« Reply #21 on: July 05, 2020, 09:03:23 am »
That one you found looks even better than what I found.  It also has the same original cutting blade design which I think is less stress on the pump.
Here is the pump thrutraffic found and sent to me via a PM.
http://www.seaflo.com/en-us/product/detail/773.html
I did a quick search and see that it is a lot more money than the generic one I used.  Shop around for the best price.
« Last Edit: July 05, 2020, 09:10:47 am by Ron Dittmer »
« Reply #22 on: October 18, 2023, 07:56:56 am »
Well.....
It seems we are going through macerators every 8 years because my replacement needed replacing.  Interesting that this time, when I removed the tired one which had been running sluggish, there was a huge ball of hair wrapped all over the macerator blades.  I was going to clean it up and put it back into service, but the blades fell off when removing the hair ball.  The rotor and blades are made of stainless steel, but the end of the motor's rotor had disintigrated, apparently poor quality stainless.
I replaced my 2nd macerator with THIS ONE, my 3rd, at a price of $52.
I followed the same procedure as before, swapping the end portion.  This time I gently clamped the macerator vertical in my vise (with wood in between) as not to disturb the gaskets and steel plates of the pump portion which made the swap go very quickly.
Also, like before, I drilled a hole in the end of the plastic motor housing to have access to the motor's rotor so I can spin it by hand with a screwdriver, in an emergency to unjamb it if required.  I stick on a round rubber pad to cover the drilled hole.
Replacing the macerator on our PC is very easy.  The hardest part which was not very hard, was the wiring.  When doing this project yourself, first test power and ground to make sure the pump is spinning in the right direction.  That got me 8 years ago because the color of the wires coming from our PC are backwords.  Black is power, color is ground.
« Last Edit: October 18, 2023, 08:18:44 am by Ron Dittmer »
JAWz
  • 9
  • PurchDate: April 2026
  • ModelYear: 2021
  • IntColor: Light wood/Grey
  • ExtColor: Dark Grey/Red/Silver
« Reply #23 on: May 10, 2026, 11:44:27 am »
I have not tried to use the sanicon system on my new to me 2021 PC 3100. The fitting that should be attached to the end of the hose is not there. The only 2 dumps I have done since buying the PC have been gravity dumps. I came from a travel trailer so this is familiar method to me. I am not sure what the real reason to use the macerator system over a gravity dump.
« Last Edit: May 10, 2026, 11:51:08 am by JAWz »
Amsoilman
  • 71
  • PurchDate: 2024
  • IntColor: Grey
  • ExtColor: White Grey
« Reply #24 on: May 12, 2026, 04:33:39 pm »
I like the “trailer” dump method myself, SWOOCH, it’s gone.  I have a square tube in front of the pull out drawer that accepts a Rino hose and fittings. Off Amazon
JAWz
  • 9
  • ModelYear: 2021
« Reply #25 on: May 17, 2026, 10:57:58 am »
I did the square PVC fence posts under my travel trailer. Worked perfect! I will need to explore a place to install on eon my PC. Right now I have one curled up on the storage bay, which I would love to use for other things.
« Reply #26 on: May 20, 2026, 12:54:48 am »
CLICK HERE to see what worked well for our 2007 model 2350.  I don't know how adaptable the storage tube from Camping World works with other models and model years.  I store a Rhino hose inside it for emergency use if the macerator dies during a trip.  So far it has been insurance alone.  The location of the tube has never been an issue concerning ground clearance or anything else, like it is not there at all.  The main gas tank just in front of it, hangs down lower.
« Last Edit: May 20, 2026, 01:00:07 am by Ron Dittmer »
NCPinz
  • 53
  • PurchDate: June 2023
  • ModelYear: 2023
  • IntColor: Mirstone
  • ExtColor: Indigo
« Reply #27 on: June 08, 2026, 05:52:18 pm »
You will want the Thetford nozzle 70400.  That goes with the retractable hose model 70424.
« Reply #28 on: June 09, 2026, 05:31:53 pm »
Because we don't do #2 in our PC, I have not yet done a gravity dump, only the macerator method.  As we continue to age, I can see a change in our bathroom practices coming soon.  Maybe then it will be more appropriate to gravity dump, but using the macerator up to this point has been a very clean uneventful experience.
Fortunately, when we needed to replace our macerator twice during the past 19 years, both times had occurred at home with time to order and install a replacement.  I do carry a gravity dump hose in a storage tube suspended under the rig (PICTURES HERE) for in-case a failure occurs during a trip.
« Last Edit: June 09, 2026, 06:08:43 pm by Ron Dittmer »
