roof and slide
  • 14897 Views
roof and slide
« on: November 18, 2014, 11:40:23 am »
  Getting ready for our last trip, I found a couple problems. As I began to put out the slide, the slide jumped as though someone was holding the bottom of slide. Checking outside the slide, I found that the butyl tape used to seal the trim around the slide had oozed out from under the trim. The butyl tape had adhered to the rubber seal at the bottom of the slide. This play-dough like substance was easily peeled off. Problem solved.
  Next, to give it a bath. Starting with the roof, I found the caulking on the rear where the roof meets the end cap was missing. The original leveling seal had leveled below the hole that should be filled. Inspecting further, I found screw heads had also come through the seal and the ends of the shower dome where showing. After cleaning and inspecting all the seals, I used Dicor Lap Sealant Non-Leveling to reseal and cover all exposed cracks and screw heads.
Re: roof and slide
« Reply #1 on: November 18, 2014, 04:20:31 pm »
Good Advice and a helpful for you.
RKS
  • 88
  • PurchDate: 1/2016
Re: roof and slide
« Reply #2 on: November 18, 2014, 08:31:37 pm »
This past weekend in preparation for our next trip I  extended the slide to do some lubricating  and noticed the metal strip on the bottom of the coach opening where it meets the bottom of the slide had a fair amount of rust on it.
Should clean up with a light sanding and some touch up paint when and if we find warmer weather
Bob and Michele
