Right Mirror
  • 15 Replies
  • 16908 Views
gl1500
  • PurchDate: May. 2014
  • ModelYear: 2551/2014
  • ExtColor: Cafe'
Re: Right Mirror
« Reply #15 on: May 04, 2014, 09:29:03 pm »
There are two ways I know to enhance your view  out the rear of your coach.  If your rear view mirror in the cab allows you to look through the coach and out the rear window like the 2552/2551 and 2350, you can purchase a square plastic Wide Angle Lens that clings to the rear window, is flexible and easily removed or relocated.  You can actually see when you have cleared another vehicle on passing.  One other item that allows viewing out the rear is the dash mounted back-up camera video.  On our unit with the Rand Mcnally GPS, with the touch of a tab on the radio, you can turn on the rearview camera while traveling and see a wide angle view of all traffic behind you.  The plastic wide angle lens can be purchased at most RV accessory stores and comes in three sizes.
