Distribution Box AVS050HD
  • 0 Replies
  • 14894 Views
« on: June 19, 2013, 02:44:40 pm »
This is a new addition to the entertainment system in the 2013 PCs. It was not on our 2011 2551. The distribution box has a built in A/V amplifier to reduce signal loss. This amplifier is powered by 12 volts from the house batteries at all times unless you unplug it. It does not shut off with the TV nor the DVD. If you are watching your power usage, you may want to unplug the power to this unit.
George
