Toilet replacement models that fit
  • 20195 Views
BarbRN
  • 134
  • PurchDate: May 25, 2013
  • IntColor: beige
  • ExtColor: tan
« on: June 19, 2013, 10:15:18 am »
Anybody upgrade to elongated china commode in the 2551?  Trying to find one that fits allowing the closet door to swing over it.  Do we need low profile?  Does the footprint work in either Thetford or Dometic styles?
Re: Toilet replacement models that fit
« Reply #1 on: June 19, 2013, 10:38:48 am »
Barb
See if this chart from Thetford helps you out.  I'm not sure what model is in the 2010 2551.
www.thetford.com/Portals/0/PDFs/toiletChartREV.pdf
Sue
BarbRN
  • 134
  • IntColor: beige
  • ExtColor: tan
« Reply #2 on: June 19, 2013, 11:25:16 am »
Barb
Sue
Sue, I had that but it's close and just wanted to verify if anybody tried it yet.  Sure appreciate your help.
BarbRN
  • 134
  • IntColor: beige
  • ExtColor: tan
« Reply #3 on: June 19, 2013, 08:53:12 pm »
OK update:  We got a china, elongated Dometic/Sealand model 320 that fits fine.  Ten minute installation.  The closet door clears fine if the lid is up, NOT the seat needed to be left up roflol roflol
Sparky
  • 334
  • PurchDate: 12/12
« Reply #4 on: June 20, 2013, 11:26:09 am »
I'm planning replacing mind later this summer different model,, I'm getting a high profile with step flush,,,10minutes wow,,,,any problems,,any tips  or just easy, good instructions??  Just curious
David  Sparks
2008 PC 2350
Houston
BarbRN
  • 134
  • IntColor: beige
  • ExtColor: tan
« Reply #5 on: June 20, 2013, 04:40:32 pm »
David  Sparks
2008 PC 2350
Houston
Only issue was that an L bracket would have been nice for the water connection.  Our plumber consult said just bend the fitting a bit and it will be fine as long as the flow is adequate and it is.  What an upgrade this model is!  Has a foot pedal too.
