Main Forum => General Discussion => Topic started by: wideglide on October 09, 2026, 09:42:26 am
As im winding down fixing all the things that were wrong with the PC from my purchase i have finally addressed the 1 light fixture over the bed. Its symptoms were the small dome light worked but the long main bulbs wouldn't so i knew i had my 12v power at least to the fixture. You have to remove the fixture to gain access to the back and on both ends there is a small access panel snapped into the fixture. The end opposite the switch contains the circuit board and the end with the switch contains an inline twist lock fuse holder. Mine had a blown 2 amp fuse in it. Replaced the fuse and now works fine. Just wanted to share if it helps anyone else. All my fixtures are now converted to LED.
This is specific to the older double fluorescent fixtures with the smaller nite light that are approximately 14 inches long.
