Main Forum => General Discussion => Topic started by: desert rat on November 04, 2024, 03:37:18 pm
Title: under cabinet strip lights
Post by: desert rat on November 04, 2024, 03:37:18 pm
Hi This is my first post. I have a 2023 2351D.  It stays in my kids RV garage. It is plugged into their wall outlet to keep it charged. Sometimes the GFCI outlet its plugged into trips. The problem is this. When they reset the breaker, in a few seconds with nobody touching the strip lights under the cabinets all turn on. The lights have accidentally stayed on for days sometimes. How or what can I turn off to prevent lights from spontaneously come on? Any help would be appreciated.
Thank you
Mike
Title: Re: under cabinet strip lights
Post by: Ron Dittmer on November 05, 2024, 10:15:30 am
Mike, for storing a PC over 30 days, I advise to disconnect the house and chassis batteries, then charge them to full using an external charger, then put that charger way, then let everything be.  I don't like keeping everything electrically active during storage periods.  I see nothing to gain, but something to potentially loose such as you are experiencing, to over-charging the batteries, to an electrical failure, or worse yet an electrical fire.
I recently caved-in and installed THIS BATTERY DISCONNECT (https://www.amazon.com/dp/B07JYDY7FQ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1) for our house batteries.  It has been a nice convenience.  I don't feel comfortable having a convenient disconnect for the chassis battery so I disconnect the negative terminal the old fashion way.
Welcome to the PC forum!!!
Post by: LRUCH on November 06, 2024, 12:48:51 am
My experience with led lighting has been good, while at the same time my experience with the switches or controls of led that come in them or attached to them is usually bad.
I don't know what kind of "strip lights" you have, but they typically are controlled by...
A thermal sensitive switch that senses the warmth of your finger.
An electrostatic switch that builds up a very small charge and you are the ground when you touch it.
A radio frequency (or worse,,,, an infrared band) is generated by a remote and the receiver is triggered by using the remote.
Or maybe a combination of these.
The thermal type can false trigger as the room changes temp, or when the sun light hits it, or when the furnace comes on and a stream of heat hits it.
The electrostatic type is the least predictable and can be false triggered not just by static in the room (including things like dust, an insect, lightning or anything that can hold a charge) , but also by static on the power source (remember how you said your gfci trips?)
The remote controls get interference from a long list of other devices, TVs, cell phones, walkie talkies, garage door openers, kids games, etc, and therefore see a higher chance of false triggers.
What's important to keep in mind is that each of these types of controls consume power, even when the light is off. They have to be powered on in order to sense the temp or static or IR blast or radio signal when you are wanting the light to come on.
All of my led lighting has an old fashioned on - off switch somewhere upstream. When I store my RV these switches are off.     You can turn them on and then use the switch or remote that came with the fixture,,,, but at the end of the trip, the toggle switches are off. No false triggers, and no trickle drain.
Larry
Post by: jimmer on November 06, 2024, 06:55:28 pm
Mike,  I heartily agree with Ron D's  opinion on not leaving the coach plugged in during storage situations.    I've read so many posts in forums about doing this and having various problems arise.
I also disconnect the battery cables and periodically charge them as needed,  depending what type you have.    I discovered this year, that even with the battery switch by the side door off, the macerator
and  generator can be started and run.
