Main Forum => General Discussion => Topic started by: KEB on August 16, 2024, 01:21:47 am
Title: Vroom Install Question
Post by: KEB on August 16, 2024, 01:21:47 am
I am looking to get the Vroom system installed on all 3 slides in my 2019 2910T. I am talking to the installer in Louisiana, Tech RV.  Dwyane at Tech RV is asking for a picture of a sticker on the schwintek slide h frame on the inside of the coach. It apparently provides them with the dimensions of the original schwintek slide mechanism and is needed for all installs.
I don't see this sticker on any of my slides. For those of you who have had the Vroom system installed, where did you find this sticker on your coach?
Regards, Kevin
Title: Re: Vroom Install Question
Post by: RonJ on August 16, 2024, 04:38:48 pm
I had the Vroom slide installed at the Vroom factory in AZ.  No mention of dimensions when we showed up for the appointment.  My guess is they manufactured the system on site at the factory and took the dimensions they needed.  I've never heard of or seen a sticker with the slide dimensions on it.  If possible, I would take your 2910T in for them to measure, then take it back in when the they get the manufactured parts from the AZ location.
Post by: KEB on August 16, 2024, 09:55:19 pm
Ron, thanks for the feedback.
I wonder if anyone else has any different experience.
Kevin
Post by: Free2RV on August 20, 2024, 06:10:22 am
Kevin,
I responded to your question on the other Vroom thread that we originally created.  I even contacted Schwintek about the sticker and they said it may not be visible after it is installed in an RV.
Gary
PS: Not sure how far you are from the place that is going to install your Vroom system, but if it is not too far, I would consider taking your PC to them and have them take the necessary measurements since you are having all three systems replaced on your PC.  That way there will be no questions about the measurements.
Post by: KEB on September 05, 2024, 02:09:19 pm
Gary,
Thanks for the reply. We are working with Tech RV in Maurice, La for the Vroom install. They are about 660 miles from us.
I contacted Keith at the factory and he had the numbers readily available for all three slides.
Post by: Free2RV on September 08, 2024, 09:10:54 am
I just saw your response Kevin.  I am glad you were able to get the information you needed from Keith.  I hope you are as happy with the Vroom system as we are with ours.  Best of luck.
Gary
Post by: KEB on January 06, 2025, 07:58:33 pm
I got my 3 schwintek slide outs replaced with the Vroom system by Tech RV in November. I could not ask for better service and workmanship than provided by Dwayne and Kim at Tech RV.
The dimensions for the slide out components from Keith did not work out.  Tech RV ended up using the dimensions I gave them to order the parts from Vroom.
Tech RV installed the 3 Vroom systems, all new seals (including an additional wiper seal across the bottom of each slide) and added aluminum plates at each roller on the bottom of the slide boxes. They also replaced a rotted floor section due to a water leak at the sidewall joint on the passenger side transition section. They accomplished this work in 5 days, as scheduled, and left my coach cleaner than when I brought it to them.
They communicated very well up front (they actually called back when I had questions) and during the repair work. I was welcomed in the shop to watch them work They have a great team and will bend over backward to make you happy.
I obviously was impressed with their service.  If you need any rv work done, you should check out these guys. OBTW this isn't a paid endorsement  :).
https://www.techrvllc.com/
Kevin
Post by: Ron Dittmer on January 10, 2025, 05:26:49 pm
I watched that Vroom video.  It sure looks like an excellent conversion/upgrade for the Schwintech.  I wonder if Vroom sells complete kits for RV companies to purchase, or do RV outfitters have to buy the Schwintech, then upgrade to Vroom.....basically buying both systems.
Post by: RonJ on January 22, 2025, 11:52:10 am
I know at one point  PC was considering having the ability to install the vroom system but that seems to have fizzled out.
