Main Forum => General Discussion => Topic started by: JRTxpress on February 08, 2024, 07:06:18 pm
While searching for the elusive docking light wiring and fuses I found the HWH power fuse (micro 20 and 5 amp) on the inside cab fusebox. (photo attached) The weird thing is after I pulled it out and cleaned the tabs, the fuse now wants to fall out at the slightest bump.
The docking light fuse location is another topic. I don't have power to the switch on the lower dash. Factory service said to drop the steering column lower cover but there is nothing there. Nothing visible behind the Garmin docking station after it was removed.......?
https://scontent.fagc1-2.fna.fbcdn.net/v/t39.30808-6/426153799_10229277472348671_1151855632921177007_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=524774&_nc_ohc=wG8sPpQPpKAAX9JTOU1&_nc_ht=scontent.fagc1-2.fna&oh=00_AfDElwcodq5OibPv8f2x0K3jg_SwoeOrLEC8sXxSaxM3hA&oe=65C964F4 (https://scontent.fagc1-2.fna.fbcdn.net/v/t39.30808-6/426153799_10229277472348671_1151855632921177007_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=524774&_nc_ohc=wG8sPpQPpKAAX9JTOU1&_nc_ht=scontent.fagc1-2.fna&oh=00_AfDElwcodq5OibPv8f2x0K3jg_SwoeOrLEC8sXxSaxM3hA&oe=65C964F4)
Buy a fresh tap-in. They are cheap enough.
https://www.ebay.com/itm/141170113661?epid=1329764726&hash=item20de64fc7d:g:BYgAAMXQC-tTCP3p&amdata=enc%3AAQAIAAAAwCArecst7YdJ884yAClzPIy90lWYREuFL3lZqPAucQkkkm2w4kF%2Bj9TX6zwKCI1CK0I4hOH7lo8jMcfXyZ3niFEx41YCcYavT4kLdZykKKtYMGnRXHebEXXD5jN4qXd99DEqUJOQSgVYFocl2qzi7ccyRMneFq%2FakD85614WG9ZRFektft3hPT30yZZb%2FVhxKd59NA8XHzHlleZrx6HgF4CAr5%2Bdtu9R%2FqBhN7O3iAIQqxWRdyy06K40zhXSUTKOJg%3D%3D%7Ctkp%3ABk9SR6CnjIazYw (https://www.ebay.com/itm/141170113661?epid=1329764726&hash=item20de64fc7d:g:BYgAAMXQC-tTCP3p&amdata=enc%3AAQAIAAAAwCArecst7YdJ884yAClzPIy90lWYREuFL3lZqPAucQkkkm2w4kF%2Bj9TX6zwKCI1CK0I4hOH7lo8jMcfXyZ3niFEx41YCcYavT4kLdZykKKtYMGnRXHebEXXD5jN4qXd99DEqUJOQSgVYFocl2qzi7ccyRMneFq%2FakD85614WG9ZRFektft3hPT30yZZb%2FVhxKd59NA8XHzHlleZrx6HgF4CAr5%2Bdtu9R%2FqBhN7O3iAIQqxWRdyy06K40zhXSUTKOJg%3D%3D%7Ctkp%3ABk9SR6CnjIazYw)
I had my coolant tank removed the other day to disconnect my Trik-l-start because of an electrical upgrade that makes it obsolete. While under there I found an inline fuse just hanging around that I believe (base on wire color) went to my docking lights. It was on pretty long leads so you could probably just feel around under there and pull it up to check. Good Luck.
