Main Forum => General Discussion => Topic started by: Fostermjd on October 14, 2023, 05:15:25 am
Title: 2013 2910d fuse and breaker labels, GFI switch
Post by: Fostermjd on October 14, 2023, 05:15:25 am
We have a 2013 2910d
We are unable to read the labels next to the breakers and fuses. Does anyone know what they should be?
Also the light over the sink and the one between the refrigerator and sink has no power. I had read where some said it could be the GFI switch. I have checked the bathroom and under kitchen sink and can’t find one. Any suggestions?
Looking forward to your help. Thanks much.
Title: Re: 2013 2910d fuse and breaker labels, GFI switch
Post by: keelhauler on October 14, 2023, 07:41:47 am
The GFI outlet is usually in the bathroom.
 (https://keelhauler.org/RV/Power%20Lables.jpg)
Post by: jim.godfrey on October 19, 2023, 09:37:13 pm
Might want to check the switch near the entry for the one over the refer. On mine, that light is controlled there so you can turn it on before entering the RV.
Also, GFI's are 120 volts. I think all of the lighting in a PC is on the 12V system so may want to check the fuse box if it is not the switch.
Good Luck!
