Main Forum => General Discussion => Topic started by: rulenh on August 17, 2023, 04:03:48 pm
Title: Door opener & lock to pc 2551 2009
Post by: rulenh on August 17, 2023, 04:03:48 pm
I have been in & out of my 2009 PC 2551 many times today, but the last I shut the door , now it will not open. I went inside over the front seat to see if I could get it open from inside.
No luck .All locks are off. Any help would be appreciated.
Thanks!
Title: Re: Door opener & lock to pc 2551 2009
Post by: keelhauler on August 17, 2023, 04:13:40 pm
Common problem with RV lock. Pot metal breaks. You can push the plunger with a screwdriver from inside where it latches. When door open it will fly away with the spring. Search on this forum you will see where to buy a replacement plunger or an entire new lock assembly. Read them all.
Post by: Taildragger on August 18, 2023, 02:47:28 am
One thing it seems is that eventually everyone has the door striker bolt failure.
Ordering a replacement is made more difficult by the door thickness of the Phoenix Cruiser.  While waiting for a replacement that fits, I operated the door by removing the striker bolt and used the deadbolt.  Key entry from outside.  Knob operation from inside.
Post by: donc13 on August 18, 2023, 09:15:54 am
Get a steel striker are..  You can get them from http://latchfix.com there is a good installation video on the site.. Watch it and see if you have the skills (not a lot required) to fix it permanently.
