Main Forum => General Discussion => Topic started by: Gracie on May 12, 2011, 12:59:38 pm
Title: Sewer Pipe
Post by: Gracie on May 12, 2011, 12:59:38 pm
Hello:  We are new to Phoenix Cruiser and need help transferring the wash water to the 3" sewer pipe instead of the sani-con.  Can someone tell us the steps please? Please list here or call 479-521-1809.  Thanks Gracie.
P.S.  We know where it is located but have not been able to send fluid through it.
Title: Re: Sewer Pipe
Post by: billy on May 12, 2011, 01:06:08 pm
just before the sani-con, under your rig should be the attachment for the "Stinky slinky"  I have used a 90 Degree elbow there to a 10" extension which brings it out for easy access.
Post by: TomHanlon on May 12, 2011, 04:41:06 pm
In order to get the water to come out the 3" sewer pipe you will still need to open the valves using the motorized boxes in the sani-con compartment. What really happens when you open a valve the water runs into the 3" pipe and the sani-con pumps it from this pipe. If you don't want to use the sani-con, hookup a hose to the end of the 3" pipe and open the valve, after placing the other end in the sewer hole.
