Main Forum => General Discussion => Topic started by: custerhank on April 26, 2023, 09:57:04 pm
Title: Connecting HR24 DTV Rcvr to T4 Riadtrip
Post by: custerhank on April 26, 2023, 09:57:04 pm
Finally got the HR24 but only getting one tuner instead of the two. I adjusted settings but Rcvr does not see the second tuner. Does it matter which cable from the Riadtrip goes into the nr 1 or 2 coax connection? One of the cables is really short but they are both firmly on. Tks!
Title: Re: Connecting HR24 DTV Rcvr to T4 Riadtrip
Post by: mikeh on April 26, 2023, 11:40:11 pm
YES!
In my 2019 2552, the primary coax for the #1 tuner is marked with a wrapping of tape near the connection.  Phoenix advised me of that when I checked trying to set up my receiver.  I assume they used that as a standard mark for all the installations.
Mike
Post by: custerhank on April 27, 2023, 12:33:28 am
Mike,
  There also 3 RCA plugs - red, yellow and white - in the compartment. Do they play a role in any of this? I do have some aluminum colored tape on the cable that comes thru the back wall of the compartment. There is also green tape on it at the connector. But that is the only cable routed that way. That cable is in the number 1 connection and does bring in one tuner . All the other cables come through the wood wall at the front including the 2nd coax which has a black tape with markings "PV6UE".
I like a good mystery and this certainly is one. I just wish I had noticed the 2nd coax when DTV tech was here yesterday. I would have let him attack this question.
Thanks again.
Hank
Post by: mikeh on April 27, 2023, 09:13:40 am
Hank--
The RCA plugs do NOT factor in.  I assume you have that audio/video amplifier with RCA connections for those cables mounted on the back wall of that compartment, as most units do, but it typically is unused and doesn't really do anything--I de-powered mine by removing the white power connection on the side to eliminate the parasitic drain from it.
That second cable that you describe coming "through the wood wall at the front" may be your coax feed running back to the bedroom TV connection--I understand that Phoenix ran that circuit regardless of whether the second bedroom TV option was installed in the RV or not.  Mine has the circuit, and I don't have a second TV.
The second cable from my Winegard dish antenna that hooks to tuner 2 runs in parallel with the cable (with the tape) for tuner 1.  In my installation, both exit from a hole in the back corner of that compartment, next to the Winegard antenna power switch.  If I remember correctly (it's been several years), when I did my set-up I couldn't find the second cable either and Phoenix advised that it would be coiled up behind the wall or something--I may have had to remove the Winegard power switch plate to find it and pull it out.  In any case, the second coax was there, and now exits from the same hole as the primary coax.
Mike
Post by: custerhank on April 27, 2023, 11:43:42 am
Mike,
  Great info. We are hdg out early tomorrow from Arizona on an 1800 mile "detour" to see family in Fort Wayne IN for a month before then hdg West back to home in Custer SD. During my free time on the road or whenever I will look for the second cable. Right now I see nothing so will call the factory just in case..
Hank
